Thread: FYI -OEM parts fast shipping
Showing results 1 to 3 of 3
    I ordered another bs delete kit this time right from a dealership. A couple of you guys recommended Southwest Mitsubishi in Texas so I ordered from them. My total bill is just $37 for the 3 pieces, shipping included. The surprise, it was delivered in just 3 days to Alaska with standard shipping.
    08-13-2008
    Waterbury, CT
    3,331
    Rear Balance Shaft Bearing - MD040597
    Front Balance Shaft Bearing - MD103722
    Balance Shaft Cap - MD092785
    Balance Shaft Stub - MD098626
    OEM Crankshaft Sprocket Spacer (for Balance Shaft Removal)- MD128107
    those are the parts to do it correctly, what parts did you order, just the bearings and stubby?
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
    cap seal, stubby and the spacer that takes the place of the balance shaft sprocket on crank. I just flip and reuse the existing bearings. It took me a while to find those part #s again, someone should put those numbers on a first page of a tutorial or something and make it easier for the next guy.
