i think your just suppose to remove the foam i just paid trigg for mine but do you have the extensions for it?
i jus got the fiberglass bumper from cali and im trying to install it, do i need to remove the crash bar to make it fit because its not fitting at all with it, is there something im doing wrong lol i was under the impression that it was direct fit as long as you remove the foam? and if you do have to remove the crash bar how do you do it i have a 03 es ive been searching for a few hours havent found anything really thanks guys
«Carlos»
yeah i got them everything seems to fit real nice except for the bumper itself
On some you just need to remove the foam, & others you'll need to shave some plastic off the crashbar. My first one from was a direct fit. The 2nd one I got after I got rear-ended needed some modding where I mentioned according to the bodyshop... Check Keith6110's OG build thread...
would u happen to have a link handy? i searched n i can only find his eclipse n his new 8g
also trim in what areas i took a look under the bumper and it seems the area not giving any play is directly in the middle so should i try shaving inwards or ? jus remove the whole thing
