Thread: Clutch squeak
Showing results 1 to 4 of 4
    Clutch squeak
    This is probably for the 5 speed swap guys. For the last week I can hear a high pitched squeak whenever the clutch pedal is pushed in or let out. It is not coming from the pedal but seems to be inside the clutch housing. Any ideas?
    do have trouble getting it to go in to gear?I would check the slave cylinder you can do that by pushing it in and it should slowly come back out if not you either have a bad slave or an adjustment issue.
    08-13-2008
    Waterbury, CT
    3,331
    my pedal does that. at least it seems like the pedal as the master and slave are new and all that stuff. im gonna try some wd 40 and report back.
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
    08-13-2008
    Waterbury, CT
    3,331
    ok so i just put some wd 40 on the part where the little pin that holds the master rod goes and my noise is gone
    2014 Lancer Evo GSR
