Thread: 05 GALANT wheels.. Help!
Showing results 1 to 8 of 8
    Hi! This is actually my first post. I just got a Galant ‘05. Pretty much stock so I decided to spend some $$ on a set of wheels. I want to get 18x8 + 225/45/18 setup Offset:45. Does anyone know if they will rub? Any other setup recommendations? Thank you!!
    05-31-2005
    4,735
    you're good.
    Welcome to TGC. Make sure to try and post your threads in the correct subforum.
    Member SirSaula's Avatar
    11-20-2010
    Dallas, Texas (Lubbock)
    286
    wont rub
    9th Generation Mitsubishi G
    TGC Texas Chapter
    Friends don't let friends drive stock. Ever
    rocgalant
    I have an '09 Sport, which has is 18x8 P235/45 out of the factory. I think our bodies are identical so you should be good.
    rocgalant
    Kinda wack in my opinion.
    Looks good as long as its not chrome. 35 offset and 8.5 wide would be almost flush with the fender.
