Thread: Fog light kit!
Showing results 1 to 9 of 9
    Rubix
    Fog light kit!
    Hey guys, I wanna install fog light on my 04 Es and I was searching for a complete kit that contain the bulbs, harness, screws and so on. I came across this one
    http://www.carpartswholesale.com/v5/...107903q1foli04 -------and would like to see what u guys think.
    1. Is it a good one?
    2. If no, what other choices do I have (please provide link) ?
    05-31-2005
    4,735
    this seems to be just for 1 housing. the harness should already be prewired.
    on the original fog light kit from mitsu, it came with 2 foglight housing, a switch, and a relay that you just all plug in.
    try calling the dealer how much they want for it.
    Rubix
    Quote Originally Posted by 9G View Post
    I contacted the dealer and he told me they don't have it and the kit has been discontinued...
    05-31-2005
    4,735
    i see.
    thats too bad. i wonder if the newer models would have the same relay kits and switch.
    the fogs you posted is the correct fogs.
    05-31-2005
    4,735
    http://www.mitsubishiparts.net/catalog/?section=336
    double check with them what comes with it.
    Rubix
    Thanks 9G! it does contain the complete kit. If I cant find anything less pricey i will get it
    05-31-2005
    4,735
    thats pretty good. i think i paid $150 for mine. that was in 04 though.
    Rubix
    I also think $110 ain't bad...i gotta wait for my greens to drop in lol!
    Your G should be pre-wired with everything except the light itself, the bulb, and the toggle switch. That one you listed will be fine but it's only for 1 so you'll need 2.
    Make sure before you put those in that you go to Auto Zone or something and spend a couple bucks for a tube of silicone to go around the edges so they are properly sealed and water proofed... many of the direct OEM replacements aren't done as well as the ones that come on the car. Better to spend 4 bucks now rather than having to pull them off later and do it.
