Thread: Headlight Assembly Removal
Showing results 1 to 6 of 6
    I have a 2004 Galant and Im planning on doing a retrofit to the headlights and installing some Bi-xenon MiniMorimoto H1 projectors..My question is, Does anybody know how to remove the headlight assembly? How many screws and bolts need to be unscrewed & where are they located?...thanks
    02-07-2007
    ORLANDO
    1,599
    hid h1 projectors? why dont you get TL or Fx35 Projectors?
    05-31-2005
    4,735
    very easy. all are visible except the bottom bolt which is behind the front bumper.
    much easier if you remove the front bumper cover which is only held by clips and the only bolts is where it connects the bumper to the fender.
    I chose the H1 bcuz of how easy they are to install with minimal modification to the headlight required.
    So basically all thats holding the headlight in place is 3 screws? the 2 that are visible and the one thats behind the bumper
    Pretty sure there are only 3 screws but one is underneath and is a bitch to get to. Might need to take off the bumper.
    10-05-2008
    Grand Rapids Michigan
    1,141
    He is using a morimoto Mini mort likely. They are not oem projectors, try are designed to screw right into several bulb type holler including h4. The output is pretty nice too, ug obviously not like a tl, fx35, or fx-r
