look from the inside of the trunk you should see them.
Righties I was trying to figure out how to remove my current one but I couldn't figure it out after all. I removed the two screws holding it on next to the license plate light but couldn't see which clips were holding it onto the trunk lid and how they were doing so. Any help? Manybrews?
Yep I saw 4 plastic parts, 2 of them I assume are the ones that the screws go into, and there are 2 more clips 1 each at the ends of the finish molding. Do I just squeeze the two outside clips and pull out? Or do I have to deal with all 4? I just don't want break anything by accident.
I just removed mine the other day. For me, I just pulled it lightly until it came off...... No harm done. Went right back on..... Just be sure to work it easy so you don't break it. :thumbsup:
Righties...hehe thanks.
