Thread: need help in opening a 5 speed trans case
Showing results 1 to 8 of 8
    HOw do you open the case on a 5 speed. I have one that the lower shaft broke on and decided I wanted to see what the insides look like before I scrap it. I have removed every bolt, pried the cases apart 1/4" so tht they are free of each other but I can't figure out how to completely sepreate them. Any help appreciated.
    jjj
    10-18-2007
    Glen Burnie, MD
    1,314
    I couldent get my old one opsn either lol
    EVO 4G
    I havent opened mine, but I would guess that there is a snap ring that you need to remove before they can come apart completely.
    Jigz-TGCIL Sosick Motorsports
    10-18-2007
    Glen Burnie, MD
    1,314
    Yea there is underneath the black cap on the end of the trans but even when I got that off it still wouldent come apart.
    North Bay...NorCal
    2,552
    IDK...I saw them just use an impact gun on mine and pry it apart. SHould be that simple.
    As I am junking this transmission I said WTF and just started prying and beating on the trans case. It finally pried apart. As best I can tell one of the rear bearings failed and seized melting itself into the trans case and snapped the gear shaft that protruded thru the bearing. The case could not just be pulled apart as the seized bearing was acting like a nut and the gear saft like a bolt. I'll post some pictures of it along with some pictures showing what is inside the 5 spd trans juts in case anyone is interested.
    jjj
    Are you a 4 or 6 cyl
    4 cyl
    jjj
