You said you cleaned the tb right. My question is did you Plug the bypass passage inlet? If you did not there IS YOUR PROBLEM. it is probable that deposits are adhered to the Bypass passage inlet when you sprayed it. So, you need to clean the passage with tb cleaner. Here some pic of what I'm talking about.
The two holes pointed by the arrows.
Spray cleaning solvent into the valve through the throttle body intake port and leave it for approximately five minutes. Start the engine, rev it several times and then idle it for about one minute.
Adjust the screw if the rpm is higher than 1000 RPM or below 500 RPM It needs to be around 750 to 800 RPM. Let it idle for 14 min. Also you need to drive the car for 300 Miles so the PCM could adjust it self.
