Thread: 01 galant gtz v6 coolant temp sensor
Showing results 1 to 3 of 3
    chrissbee7
    Can't seem to locate the coolant temp sensor. I keep getting a check engine light on for the sensor also the temp gauge does not work. however; when you have the car running and clear the light with the scan gauge then the temp gauge seems to work fine again until the light pops back on and its back to not working.
    06-13-2008
    Bronx, NY
    2,606
    Here you go man. Good luck
    SOHC Turbo
    Just follow the upper radiator hose towards the engine. The sensor resides in that coolant manifold.
