Thread: how to hide this
Showing results 1 to 13 of 13
    how to hide this
    what would i use to hide the wires
    [IMG]<a href="http://s1238.photobucket.com/albums/ff488/gvp1632/?action=view&amp;current=FILE0008.jpg" target="_blank"><img src="http://i1238.photobucket.com/albums/ff488/gvp1632/FILE0008.jpg" border="0" alt="Photobucket"></a>[/IMG]
    just cut some plastic and fit it in there to cover the wires
    04-13-2005
    Chicago
    1,945
    that would be your best bet man.
    n3oAcid24 = 01' Galant I4
    You should be able to find a dash install kit for a 1/2 din equalizer.
    I've been looking to find a pocket to put in there so I can throw stuff in there.
    02 Galant GTZ stock
    00 S10 Bagged on 20's Suicide Doors 5 link and control arms, more to come!
    Quote Originally Posted by kingscratchie View Post
    i went into google and typed in "half din pocket install" and this was the first result:
    http://www.amazon.com/Metra-Universa.../dp/B00032AZT6
    black painted carton may work
    __________________
    -Mitsubishi Galant (4G64 SOHC) ES 1996, 5spd Swapped.
    -Mitsubishi Galant LS 1994 a/t [ SOLD ]
    If that's just layin there, it won't be secure causing wires to come loose and give you problems. Get the above mention kit, so it's mounted, secure and with no gaps. You may have to modify with a Dremel if one is not available... razor blade with a steady and careful hand.
    You can also try....
    http://www.parts-express.com/pe/show...ource=googleps
    I have created wonders with this stuff.
    Before
    After
    This is is not for everyone,some may think it's cluttered, but every button has it's purpose
    thanks
    TGC Regular joegalant's Avatar
    08-09-2010
    ronkonkoma ny
    745
    that a blazer?
    I kinda like it. Nice....
    The key to Immortality is first living a life worth remembering.
    Quote Originally Posted by joegalant View Post
    that a blazer?
    04 Chev Tahoe
