Thread: AC and Radio won't turn on
Showing results 1 to 2 of 2
    I initially assumed I blew a fuse, but when I checked them, they all looked good. I was changing the dome light when this happened. If anybody can tell me wtf happened then I'll be very grateful.
    When I turn the key to the "on" position, the odometer and speedometer work etc. but it's possible those lights don't work either. The radio and the AC don't turn on with the car. I noticed the dome light isn't working at all and it's possible those lights aren't working either. I'm hoping somebody else has run into this problem.
    Nevermind, here is the answer:
    https://www.thegalantcenter.org/show...=lights+inside
    Can't for the life of me figure out how to delete this thread though.
    Solution credit to joegalant, "its the fusebox under the hood ive blown that fuse be4 on mine the fuse is in the back drivers side theres a yellow box around around it with two fuses in it its one or the other "
