Thread: 2.4L 02 Galant ROM and XML flash *progress*
Page 2 of 6 FirstFirst 123456 LastLast
Showing results 21 to 40 of 118
    06-13-2008
    Bronx, NY
    2,606
    Added new maps. KNOCK SENSOR FILTERING.
    SOHC Turbo
    08-18-2004
    Charlotte, NC
    1,029
    send your rom to the email you provided.
    1994 GS FYI
    DSM/CSM Manuals
    08-18-2004
    Charlotte, NC
    1,029
    open loop tables
    In reference to the open loop tables:
    http://www.aktivematrix.com/forum/viewtopic.php?t=86
    http://forums.evolutionm.net/ecuflas...loop-load.html
    Basically open loop load and throttle affects when the ECU goes into open loop sooner or later. Open Loop Load is based on the ECU load while Open Loop Throttle is based on TPS voltage or percentage.
    1994 GS FYI
    DSM/CSM Manuals
    06-13-2008
    Bronx, NY
    2,606
    Thanks bro. I will take a look at that. Yeah Big power drop around 750-2000 rpm with the maps. I will have to do a few test and adjust the open loop more.
    SOHC Turbo
    06-13-2008
    Bronx, NY
    2,606
    Thread updated
    CHECK PAGE 1....
    New maps added.
    SOHC Turbo
    05-03-2007
    Socal/Central Coast
    3,803
    hm I need to catch myself back up on this. Might not be for the V6 but knowledge is good.
    06-13-2008
    Bronx, NY
    2,606
    It will work the same. Is all about how things work in our engine computer. 2.4l pcm is as good as the eclipse for ecu for tuning. People who dont want to do a ecu swap and just have add-ons and 5 speed stock pcm is the way to go. Just add a knock sensor to stock pcm. * in progress* and you are set.
    SOHC Turbo
    06-13-2008
    Bronx, NY
    2,606
    Post update 8/12/11. Check page 1
    SOHC Turbo
    I appreciate your dedication in tuning for galants!
    06-13-2008
    Bronx, NY
    2,606
    Quote Originally Posted by Exhaust power View Post
    no problem. There a lot of potential on the stock computer without going with the eclipse manual or evo ECU. It just need the time to test and finding the core code of the ROM. Big progress on it.
    SOHC Turbo
    Hope all goes well i wanna keep the stock ecu if i can. So looking at the maps your able to tune up to 7k?
    06-13-2008
    Bronx, NY
    2,606
    It could be tune. But Stock rods and setup will only go to 6300K, so to be in the safe zone only rev to 6100K, with a good tune you could make a good amount of power on 4000-5500K RPM. Only a built engine with forge internal will go that high 7000K + RPM.
    SOHC Turbo
    When i swap to a G4JS block im planning on running and tuning to a 7k redline which is only 500 rpm more then that engine original redline. Theres been a couple of threads ive read that our engine in fact can run to 7k safely. I wouldnt run it stock because i have no supporting mods like cam and a higher CR.
    The direction this tuning is going i cant wait to start building my engine.
    06-13-2008
    Bronx, NY
    2,606
    big progress. By the time you are done. The will be a lots of progress. You need to get a knock sensor.
    SOHC Turbo
    Theres a 9g galant at the jy im going to see if i can grab one i would like to grab the lighten crank shaft from it too.
    knock sensor
    Im not quite sure how you will accomplish the knock sensor? As far as i am aware our ecu does not have a physical pin for the knock sensor so you would have to code the crap out of the ecu to get it to accept knock..
    Maybe a pin that isnt being used anymore can be overwritten?
    06-13-2008
    Bronx, NY
    2,606
    The harness dont come with the pin. The pcm brings the ping and is not been used. If u chech the first page. I found the knock sensor filterring meaning the code is there. All u need to do is to get a knock sensor with the plug. Run a wire straight to the harness to the pcm. I will try that sometime this week or next
    SOHC Turbo
  19. #39
    knock sensor
    sounds good. I would think that you would probably have to activate the knock sensor also. It may be disabled from factory via periphery bit but you will find out when you try it. I have not looked at my high and low octane timing maps on the galant -- if it is a different map from high to low then you will certainly need to find away to activate it.. Good luck.
  20. #40
    06-13-2008
    Bronx, NY
    2,606
    Quote Originally Posted by Johnathansgalant View Post
    I belive is activated. Since the pcm is not receiving a signal from the knock sensor the galant 4g64 only uses the low maps always.
    SOHC Turbo
