Thread: 2.4L 02 Galant ROM and XML flash *progress*
Page 5 of 6 FirstFirst 123456 LastLast
Showing results 81 to 100 of 118
  1. #81
    06-13-2008
    Bronx, NY
    2,606
    Quote Originally Posted by underated View Post
    have you looked into the 85850014 rom its for the 2000 galant es a/t if you dont have it let me know and ill send it to you with the definition file
    has knock sensor maps already defined... maybe you could work on a universal rom for 00-01 and 02-03 kind of like the evos have for the 8's and 9's instead fo doing individual definition files
    There is no universal ROM. Every rom is unique with there memory locations. They all have knock filtering not knock sensor on the Galant it needs to be added via hex. The thing is to define it and find the correct locations. You can't just copy one xml to the other. Universal ROM..... MAYBE. I would say.... 2001-2003 we could use any rom on the PCM. Like you could use my 02 rom on a 03 PCM.. but you need to get the immobilizer out. 99-00 could use the same rom.
    SOHC Turbo
  2. #82
    06-13-2008
    Bronx, NY
    2,606
    added new info. Check page 1
    SOHC Turbo
  3. #83
    I pm'd spd_frk like 3 weeks ago and no response lol :( if I were to retune my car can I do it via obd-II CABLE and laptop?
  4. #84
    06-13-2008
    Bronx, NY
    2,606
    Quote Originally Posted by NewGalantKid View Post
    You need Tactrix 2.0 with mitsu reflash connector, evoscan, AFR wideband, working xml for your rom.. And know what you doing.
    SOHC Turbo
  5. #85
    08-15-2006
    Perth Amboy, NJ
    1,558
    ECUflash too
    run1206's Rear Disc Tutorial
  6. #86
    06-13-2008
    Bronx, NY
    2,606
    Lol thanks. That too. It should be given if you get the tactrix
    SOHC Turbo
  7. #87
    06-13-2008
    Bronx, NY
    2,606
    update on a 2000 Galant PCM map
    3 maps. 3 fuel, 3 timing. First time i have seen on the galant PCM. Only the evo9 have 3 to 4 maps.
    SOHC Turbo
  8. #88
    Get used to working with it ;) he he he
  9. #89
    06-13-2008
    Bronx, NY
    2,606
    Lol..
    SOHC Turbo
  10. #90
    Its like Chinese to me right now. But later down the road ill be picking it up slowly. I have a 2000 pcm hope thats a good start!
  11. #91
    Doesn't really matter what u have Isaurio is da shit!!!!
  12. #92
    08-18-2004
    Charlotte, NC
    1,029
    V6 or I4?
    1994 GS FYI
    DSM/CSM Manuals
  13. #93
    06-13-2008
    Bronx, NY
    2,606
    Mysticj- i4 maps.
    SOHC Turbo
  14. #94
    I know this might be dumb but will this allow you to re flash and turbo with the stock ecu even an auto?
  15. #95
    06-13-2008
    Bronx, NY
    2,606
    Quote Originally Posted by 94supratalon View Post
    Yes "BIG MAPS ONLY". Better resolution for tune. And stock pcm is not limit to 100 load. It could read and give timing and fuel calculations for 100+ loads. This is only done on the big map patch rom. No on stock rom.
    Stock rom could be tune for smoothness to give better performance but not for boost.
    SOHC Turbo
  16. #96
    06-13-2008
    Bronx, NY
    2,606
    My new big map open loop adjustment.
    SOHC Turbo
  17. #97
    so i have an 01 gtz manual swap, how would i go about clearing the trouble codes?
  18. #98
    TGC Regular bgood12's Avatar
    07-17-2009
    554
    Hey one thing isaurio, I saw what I need to tune my engine, but seeing as you seen to know coding I'm trying to add in all the prices for CAPS ASA 8 g galants as a summer project. I have managed to get a scraper to give me the part numbers and prices of parts off a mitsu parts website. I have seen it done where in caps you get external prices via an .txt file I tried to this and put my info in a .txt file and it did not accept my files eveb though I put them in same format as the one that had worked (from 3si 3000 GT site). I tried looking at spacing of numerals etc any thoughts?
    Sent from my BlackBerry 9360 using Tapatalk
  19. #99
    08-18-2004
    Charlotte, NC
    1,029
    anymore progress on this Isaurio?
    1994 GS FYI
    DSM/CSM Manuals
  20. #100
    06-13-2008
    Bronx, NY
    2,606
    Quote Originally Posted by dknight3 View Post
    If you have tactrix 2.0. If you send me your rom i could help you out with the trani codes.
    Send me a pm for more info.
    Quote Originally Posted by bgood12 View Post
    I'm not understanding your question. What exactly you want to accomplish?
    I have worked and running with my 2.4L big map for about 3 months now, Testing, adjusting and trying to avoid knock. so far i tune up to 100 loads. Soon i will test the big map for boost reading, meaning to get reading above 100 loads. Right now it is set to 200 loads at 7500k RPM let see if i find any bugs.
    If it works i will start making a standard basic base rom for members to try. This is going to be base on my 2.4L 02 ROM stock rom.
    NOTE: this is a 512Kb SH rom Late 01-03. People using the H8 ROM is only 128Kb wont be able to flash the rom due to the small memory block. This is 99-early 01.
    SOHC Turbo
