alignment
For some reason they are wearing down extremely fast. I bought four brand new tires a little over 7 months ago. The front one's look really good but the back one are bare. even on the side's. Any idea as to what maybe causing it?
Thanks.
"A smart man can learn more from the questions asked of him than the questioner does from his answers.'
I did alignment and everything when I got the new tires and toes? I'm lost, what is that.
hmm lets see if I can explain this right... ahHA! ok you know what pigeon toed is right? where your feet kinda rotate in towards the big toes? Basically your tires are doing that on the rear, so they are rotating BUT at the same time they are being drugged across the pavement.. Hope that helps lol
http://www.ozebiz.com.au/racetech/theory/align.html
UNDERSTANDING TOE
When a pair of wheels is set so that their leading edges are pointed slightly towards each other, the wheel pair is said to have toe-in. If the leading edges point away from each other, the pair is said to have toe-out. The amount of toe can be expressed in degrees as the angle to which the wheels are out of parallel, or more commonly, as the difference between the track widths as measured at the leading and trailing edges of the tires or wheels. Toe settings affect three major areas of performance: tire wear, straight-line stability and corner entry handling characteristics.
For minimum tire wear and power loss, the wheels on a given axle of a car should point directly ahead when the car is running in a straight line. Excessive toe-in or toe-out causes the tires to scrub, since they are always turned relative to the direction of travel. Too much toe-in causes accelerated wear at the outboard edges of the tires, while too much toe-out causes wear at the inboard edges.
Sounds like that's my problem. How do I fix it?
Thanks again.
