It sounds like your bulbs are blown or something might not be completing the circuit something could be loose.
My S7 gauges just went out (no lights..but still work)....it's wierd b/c not only did they go out but the needles went out as well. I've had the gauges go out before but never the needles. I though it may have been a blown fuse but checked that and it's fine....any other ideas on what it could be?
Thanks.
Fellas, I just met with DTC for the first time and while taking some pics he noticed that my tail lights were out (break lights were working though). It was getting close to dark so I hurried home ....but on the way the gauges and tails begin to work once again. However, now they are not working. Any thoughts?
I would pull the cluster, you need to ensure all the connections are solid and secure.
Seems like a bad ground on the tail light side of the parking circuit
Sent from my iPod touch using Tapatalk 'cause I'm awesome...
-Andrew
Does anyone know how the tails and the gauges interact with one another.....ie: are they on the same circuit?
