Thread: Will adding turbo reduce the engine life?
Showing results 1 to 6 of 6
    stormcruiser
    I was curious if adding turbo will shorthen the life of the engine?
    Another thing I was curious is turbo car such as subaru WRX have shorter engine life than the cars without turbo? Thanks~
    it depends. i mean if u slap on a turbo on a car not designed for it, its not gonna last as long as one that was designed for it. turbo cars need more maintenance. and the way u drive it too will affect it too. so all in all it comes down to 3 basic things. they way its built, the way its driven and the way its maintained
    Kain
    In short...yes. A turbocharger will always shorten the life of an engine. Proper maintnance can go a long way to combating this, but the extra heat, strain, wear + tear, and pressure that a turbo puts on an engine simply wears down the parts faster. Take care of it though, and you're probably talking less than 5k miles total life shortening of a turbo vs a N/T car.
    09-22-2002
    Kissimmee, FL
    1,495
    Maintance is key, with any turbocharged vehicle.. You gotta stay on top of it or you will loose your motor is a matter of months, instead of years..
    Spyder4G64t
    There are plenty of turbo motors out there with 200k miles on them w/o any problems. I was just at a Dyno at AMS in Chicago this past weekend, and a friend from our local WI DSM group had his 150k mile stock internal engine put down 305whp w/o any problems. It's really not something you have to worry about. Maintenace (as everyone said) is very important.
    HiperSilver
    a DSM is built for a turbo, i know guys with 200k plus miles smoking the shit outta ls1's. Its not somethign to worry about on a engine wiht a turbo but if u slap a turbo on the 4g64. Hell yes you will fuck it up. just run safe boost, lower the compression , get a thicker head gasket. On top of that forged pistons, stronger rods. now you got the bottom end built, you might wanna go DOHC later on, better breathing and you can control exhust and intake lift and duration with 2 seperate cams, great for tuning.
