Thread: auto trans with a turbo...
Showing results 1 to 20 of 30
    4g64turbo
    How much HP and a stock trans handle ( with a trans cooler on it)?
    11-18-2009
    Buffalo, NY
    1,758
    I believe the limit is 250hp not 100% sure though
    - Chris -
    DRL Delete
    06-13-2008
    Bronx, NY
    2,606
    Nahh. I thinks is less. Boost limit is 3-5 PSI. Dont really know. But dont take any chance. go 5 speed. Save up and do it right the first time.
    SOHC Turbo
    ^no hold on I know qnz has an auto and is turbo'd along with Scott, at 20 psi, and that seems to run great. Its all in the tune, and how you drive, if you drive like a bitch, then your proabaly going to destroy the tranny.
    4g64turbo
    I drive good, I don't drag race and I would only start boosting why im driving not at a stop.....if I can get 350 hp then I would be happy.....
    06-13-2008
    Bronx, NY
    2,606
    NO. the tune only works with the stock "engine" internals. There is no tune that have pull out the other 256k of the transmission memory to tune it. So, is no way 20 PSI on stock auto is possible, it will only run up the block, unless is a built trans. To be in the safe side 5 PSI on stock transmission is fare, and will only run for so much. People running more than 8PSI or more on a auto they running built trans. 350 HP will only be possible with a 5 speed or a built a/t trans "NO STOCK internals on TRANI.
    SOHC Turbo
    I guess you miss understood me. I was saying that its all in the tune for the motor to run right, and YES you can run 20 psi on the stock auto tranny, its been done, scotts g is a dohc stock block, auto with 20psi. Now just because its been done, doesn't mean that its the right way or should be done like that, but not everybody wants to go manual. And I didn't say that the tranny would last long on 20 psi, I said it would run lol
    11-29-2009
    Chadds Ford, PA
    2,768
    and boost is just a figure 10psi on one turbo is completly different on another turbo, you need to look at the flow range and efficency of the turbo and what turbo you run. boost has no effect on you tranny. the thing that kills trannys is power and torque.
    It depends where you measure it from, I personally, tapped my mani for the BOV and Boost gauge.
    Also from boost, comes power and torque
    06-13-2008
    Bronx, NY
    2,606
    Bottom line is this, you wont make 250 or 350 HP on a stock auto trani even with a cooler.
    Stock trani = weak internals.
    SOHC Turbo
    yes thats true, but why not give it a shot? lol
    Just go 5spd, you will feel like you're boosting with it alone.
    08-04-2003
    NY
    4,344
    I gotta disagree with this one. Qnz has been turbo for several years on the auto trans with an upgraded cooler and has no trans problems that I know of. I think his car is making in the 200-250whp range.
    99' Galant ES
    4G64/63T
    AEM EMS
    06-13-2008
    Bronx, NY
    2,606
    Really.. UMMM. QNZ do you have any dyno sheets?
    SOHC Turbo
    02-07-2007
    ORLANDO
    1,599
    lol if im not mistaken on his hks fcon setup he made 263 hp
    Quote Originally Posted by 02redgalant View Post
    +2 on this. Yes, he made around 263whp on A/T.
    TURBO= in the making.......
    I'm currently at 240 whp on the auto trans. It doesnt shift so great at WOT on the track, but it shifts perfectly fine driving on the highway and street.
    I know most of you guys dont remember manybrews. He was a mitsu tech on TGC way back in the day. But he said our auto trannies are built damn strong. After beating on my car with tons of highway miles/pulls last 2 years, I gotta agree with that.
    06-13-2008
    Bronx, NY
    2,606
    sounds good to me. My auto trani went to crap and is not even turbo. I guess every trani is different.
    SOHC Turbo
    ^^Service intervals maybe?
    06-13-2008
    Bronx, NY
    2,606
    nahh bro. fluids are up to date. Super pink and don't smell like burn.
    SOHC Turbo
