Thread: USDM front indicator plugs - where to find em?
Showing results 1 to 3 of 3
    I'm in the process of gathering bits and pieces to fit USDM front turning lamps/indicators to my JDM Galant. I've got the sockets to fit in the headlamp assembly, but i can't find the right 3-pin loom plugs that match the indicator socket in Australia, as the 5/21 watt indicators aren't available here in any Mitsubishi.
    Where can I find these loom plugs on-line?
    Cheers!
    05-14-2010
    Coachella, CA
    5,954
    Ebay.
    Or contact mrg7243, he's always out at salvage yards and those sockets are not a big sought after item here in U.S.
    Quote Originally Posted by Smitty View Post
    Cheers!
    we reuse our USDM turn signal socket in our JDM headlight conversions. you may be able to simply reuse your JDM signal socket and bulb in the USDM headlights. are the JDM signal bulbs not dual filament?
