Thread: quick question on + line from amp to battery
Showing results 1 to 9 of 9
    TGC Regular Da_Prodigy's Avatar
    01-29-2010
    Elgin,IL (Chicago Suburbs)
    593
    How did most of you install ur + line from the amp to the battery? I know I could always peirce through the firewall but if I remembr correctly someone fed the line through the side fender. I tried searching but couldn't seem to find the thread I was lookin for and being on mobile internet doesn't help much either. Any advice would be apreciated.
    BTW I have a '00 G.
    06-16-2010
    Fort Mill, SC
    2,282
    There's a hole in the firewall that was drilled out for my power wire... I'll look for you.
    -Andrew
    4,455
    There is a hole where the clutch pedal would be if the car was manual. I ran my wire through there. If you look up under the dash to the left of the brake pedal you will see a flap you can move and its right there
    Jason - - cofounder of TGCNY
    2001 Galant ES
    yeah i did the side fender threw the hardness boot
    06-16-2010
    Fort Mill, SC
    2,282
    Quote Originally Posted by mrjaydeeone View Post
    This.
    -Andrew
    yea i ran mine through by the clutch
    01-29-2010
    593
    Decided to run it through the side fender for a more cleaner look.
    TGC Regular joegalant's Avatar
    08-09-2010
    ronkonkoma ny
    745
    wow i must have drilled my hole right next to that with out even seeing it lol
    Quote Originally Posted by Da_Prodigy View Post
    That can get kinked and with weather overtime strip the insulation expose the wire and short out...
    Best way drill through firewall, install a proper size grommet to prevent tug/pull and then hide your tracks with a little loom.
