THROTTLE POSITION SENSOR CHECK
M1131003200053
Required Special Tool:
MB991348: Test Harness Set
Checking the Terminal Resistance
1. Disconnect the throttle position sensor connector.
2. Measure resistance between the throttle position sensor
side connector terminal 1 and terminal 4.
Standard value: 3.5 − 6.5 kΩ
3. Measure resistance between the throttle position sensor
side connector terminal 1 and terminal 3.
4. If resistance is outside the standard value, or if it doesn't
change smoothly, replace the throttle position sensor.
NOTE: After replacement, the throttle position sensor should
be adjusted.
