The easiest way to do this swap is search. There are tuts posted on what u will need n everything on this forum
Hello, im new to the site and im preparing to do a 5sp swap to my 01 galant v6. I have a complete 01 spyder v6 with manual trans as a donor. what would be the most trouble free way to do this swap? what sort of computer work will i need? jus, want to get all my ducks in a row before i start. thanks
sport
yep, your new
here's a link to a how to page
https://www.thegalantcenter.org/showthread.php?t=34842
while I haven't done this swap myself, it isn't the most difficult thing ever, just follow the intructions, and if you have problems, post up and describe thme
thanks for the quick info. i did read that swap tutorial , great thread , but , i am swaping both engine and tranny from the eclipse to the galant, i dont want to dissasemble anything i dont have to. thanks again
U get more hp with the eclipse engine? I should of gotten my mechanic to do that last yr when i blew a head gasket. Instead I just another galant engine. But of course i didnt know then what i know now
There aren't many differences between the two. You're fine with the Galant engine
EDIT:
Just saw you have a 4g64. They're the same.
No. The Eclipse GT/GTS has the 6g72 (just as 8g's with V6 do)
Eclipse RS/GS has the 4g64 (like 8g with I4)
yea, thats where my concern is the most. ecu and wiring
I'll post this pic since I don't know why there always doubts on the wiring:
And on the clutch pedal there are 2 connectors you can leave them unplugged unless you want to have to depress the clutch pedal to start the car.
And if you want to get rid of the SES lights swap the eclipse ecu, but you'll need to buy a conversion harness from here: http://www.blackheartmotors.net/conversion_harness/
4g64T 5spd
If your going to swap all the harness over from the 3g to the 8g, your going to need the eclipse ecu, because the connectors to the ecu are different on the 3g compared to the 8g. I don't know if anyone has done that, and IDK if the engine fuse boxes are the same layout, same with the inside fuse boxes.
eclipse has no ecu, dash or interior, it was sold already. picked this car up from a auto repair company that was parting it out. I got everything i need for $500. i just do not have the knowledge. but you guys are helping tons.
btw i dont care about the ces light its been on forever (bad #6 cylinder) i will most likley take out the led or hope it burns out - since i regularly scan it for codes when i change the oil.
a conversion harness on the galant ECU should do just fine then for the engine+transmission swap
