Thread: How to: Mod USDM Grille to fit JDM Heads
Showing results 1 to 20 of 23
    Note: I am not responsible for any damages to your grille, bumper, headlights, and your fingers.
    OP Notes: This is an old request from Kalamidad 6 years ago but never came to light. Basically, it was inspired from Krispy03 build but there were no actual -how to's- tutorials anywhere. So enjoy!
    How to: Modify USDM Grille to fit JDM Heads
    (this applies to 99-01 griiles and 02-03)
    Here's a pic of the ghetto install:
    (Wrong Way!!!!)
    (you can't really see it unless unless you're up close...)
    Here's a few tips why it was installed wrong:
    - sides were not shaved for headlight clearence
    - because sides were not adjusted right the tab mounters will not allign
    - lower tab mount rubbing against the bumper thus making it look warped and sticks out of the bumper.
    The correct way:
    All you need are:
    - Dremel or any rotary tool (cutter & sander bits)
    - one functional oem grille
    1. On the first pic, notice the corners has been shaved off slightly (with a rotary cutter) to give some room for the jdm heads. To make this fit, I made no additional cutting necessary just the corners you see below.
    2. Using the rotary cutter I cut 3/4 to 1 inch from the end of the grille. If you notice from the pic below I cut through by following the contours of the grille. This was to make the grille fit within the contours of the headlights.
    3. Using a rotary sander, I sanded the back of the grille from where I cut from step 2. This will ensure the grille wouldn't rub against the headlights.
    4. Using the rotary sander, I sanded off a small layer from the 3 bottom bottom tabs to prevent it from rubbing against the bumper
    5. You will be using all but 2 mounting tabs. All top tabs will be utilized. On the bottom tabs, only the middle will be used as the 2 corner tabs has no place connect (or obvious reasons)
    This is the finished product. The grille is flush with the bumper, no warpage, and nothing sticks out as if it was forced in (no homo). This tutorial may be appled to 02-03 grilles as basic design are similar to the 99-01 design. Enjoy! :)
    12-13-2010
    Brooklyn, Maryland
    4,643
    I was waiting for the tut after I saw this in the "Post What You Did..." thread!! Nice writeup!
    -Greg
    06-13-2008
    Bronx, NY
    2,606
    nice. but the USDM is still a ugly grill. -_-
    SOHC Turbo
    x2! I won't do it, but nice to see it done and written down lol. Good Job
    Eclipse GT 5 spd swapped
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
    that looks like the grill doesn't fit, like it's sticking out too far. why not just use a JDM grill?
    That's not the point of this tut. I didn't do this to prove anyone wrong. I did this because the ones who have done it in the past installed it poorly. I do have a JDM grille. In fact I have 2 of them sitting in the garage. This tutorial was made in request from Kalamidad a while back. They look flush or else I wouldn't bother making a tut for it. I also have better pics I'll post them later tonight.
    Quote Originally Posted by G-spot View Post
    huh? they don't look as flush as a JDM grill w/ JDM headlights (or USDM headlights w/ USDM grill) does. maybe it's just the pics u posted but the grill looks like it is protruding out further than the headlights and it is not only too big but is also not flush to the bumper on the bottom edge making it appear to float. this tutorial could be helpful for ideas for the '02-'03 grills to modify them to accept JDM heads i guess, but for the '99-'01 grill, it's both easier and much better looking, to just use a JDM grill if you go w/ JDM heads.
    07-12-2007
    SoCal
    4,632
    Good tutorial G-Spot, this gives members other options for different combinations of parts.
    JDM Zenki Conversion
    Understandable but if someone cant afford one then this would be the better option......for the mean time anyway
    Quote Originally Posted by G-code88 View Post
    if they are buying JDM heads, they can afford a JDM grill. these parts are many times cheaper than they were in the past.
    07-12-2007
    SoCal
    4,632
    Not everybody has enough money man. So if they cant afford a JDM grille when they buy the JDM heads, then they can do this for the inbetween time until they can.
    Well said.
    I like the idea, however it seems like the grill sticks out in front of the lights too much, maybe it's just the pics.
    There's alot wrong with this car, everything clashes...
    Quote Originally Posted by greddy View Post
    i think ur seeing what i'm seeing. g-spot says it's just the pics.
    11-29-2009
    Chadds Ford, PA
    2,768
    I see it in all the picts
    maaren
    Please look at my solution. ;)
    07-13-2005
    * Upstate NY *
    1,289
    Great mod to save some cash. Good work G-Spot.
    12-13-2010
    Brooklyn, Maryland
    4,643
    Quote Originally Posted by maaren View Post
    [IMG]http://s013.radikal.ru/i325/1112/ca/d941f705f4cd.jpg[/IMG]
    [IMG]http://i023.radikal.ru/1112/dd/0dd2764e4c13.jpg[/IMG]
    [IMG]http://s016.radikal.ru/i336/1112/7d/73234654fd0a.jpg[/IMG]
    How much material did you cut out of the grill to make it fit like that? and what glue/epoxy did you use to put it back together? Looks really good.
    -Greg
    maaren
    As you can see, I cut something about 1.5cm from both sides, maybe a little bit more.
    About glue I don't remember, what I found in garage I used. ;) Just put it more from behind and left for one day.
