Thread: Guzm4n's 8G Build
Page 7 of 11 FirstFirst ... 34567891011 LastLast
Showing results 121 to 140 of 207
  1. #121
    A padded shroud will not help since the battery hold down bolts will still be outside the shroud. In my instance, I relocated the battery because my Injen intake would not fit properly after my Diamante plenum swap.
  2. #122
    I'd rather have stock piping with a K&N or some other cone filter than waste $200 on a CAI....
  3. #123
    TGC Regular Guzm4n's Avatar
    02-02-2011
    Des Moines, IA
    736
    Since your injen didn't fit right then I'm going to keep the stock piping and do what blue said.
  4. #124
    ^^It really is pretty much the same thing. I replaced mine only because the resonator close to the TB fell off and the tape would no longer hold up to the summer heat, but up until then I ran the stock tube and specter filter. And in the short year I had the aluminum eBay pipe it had already started to show wear from the battery.
  5. #125
    why?
    Jigz-TGCIL Sosick Motorsports
  6. #126
    Not like any real gains will be mad either way, why not just stick with something that will always fit like OEM?
  7. #127
    So why not stick with the OEM airbox as well?
    OEM is not always better. Take it from someone who works on OEM shit all day everyday. Some of these designs these engineers get paid six-figures for are total garbage. Like they've done a hallucinogen right before they hit the drawing board. OEM is NOT always better.
    The "accordian" part of the stock 8G intake alone creates turbulence in the air flow through the intake that it actually decreases airflow going into the throttle body.
    I used to think the whole $200 intake was garbage as well but I've seen it enough times to see theres actual advantages to a legit straight through intake than just slapping a cone filter on the stock intake.
  8. #128
    02-02-2011
    Des Moines, IA
    736
    I removed the stock airbox because the intake manifold made the intake pipe more to the right, so I decided to put a filter on so it would be easier to put on the intake pipe.
  9. #129
    Jigz, I know that OEM is not always better, they have to do things that may just be 'fine' in order to achieve other goals that are deemed more important.
    I'm just saying for the little gains to be had I couldn't justify the $200.
    And I would just leave the intake box haha
  10. #130
    02-02-2011
    Des Moines, IA
    736
    I was reading in c3g about cutting the intake pipe an inch and a half so it doesn't rub against the battery. Has anyone done this?
  11. #131
    05-03-2007
    Socal/Central Coast
    3,803
    this is old but.. my solution is just to get a smaller battery
  12. #132
  13. #133
    Nice color scheme under the hood
  14. #134
    02-02-2011
    Des Moines, IA
    736
    Thanks guys!
  15. #135
    Member
    06-18-2012
    RIVERSIDE CA DAT 951 AREA CODE LOL
    183
    The color looks gd bro
    GWAP STACKIN MAKE'S IT HAPPEN
  16. #136
    02-02-2011
    Des Moines, IA
    736
    Guzm4n's 8G Build
    Really late update:
    The 5-speed swap was alright, it was a PITA at times (like changing out the shifter cables) but it was also my first time doing something like this. I think it might've been easier if I pulled the engine with the transmission out and just swapped the transmissions outside the car.
    Here's some pics from the swap:
    So when I was doing the swap my cousin happened to buy 9g in red lol!
    The axles, hubs, and knuckles
    The auto transmission out
    The auto starter plate off
    Flywheel on
    Exedy clutch on
    Manual transmission ready to go on
    All done!
    It was supposed to be lowered yesterday but something came up, so hopefully I can go low this upcoming weekend.
    Okay so I've been thinking about my exhaust setup & wanted to get some opinions. I want to do RPW long tube headers with the eBay piping that comes with the eBay exhaust (since I've read it's not that bad) and a Greddy SP2 muffler. Is this alright or should I do something different?
  17. #137
    nice work! looks like youve got a nice shop to work on it in. lots of room!! cars coming along great, keep up the good work!
  18. #138
    02-02-2011
    Des Moines, IA
    736
    Guzm4n's 8G Build
    Thanks man, that's actually my uncle's garage, in his house, lol! He doesn't keep anything in there so he let me bring all my stuff over & do the swap there, the downside is he lives 45min away.
  19. #139
    its a heck of a lot better than doing it on your back in the street on a 30 degree day!
  20. #140
    Never heard an actual greddy, but Tsudo makes a replica that I thought sounded nice. If it sounded good on a 4cyl, I imagine it would sound even better on our v6's. You can find em on ebay or the retailer of your choice..just type tsudo sp2
    http://m.youtube.com/#/watch?v=bZ3g2...%3DbZ3g2Eg3Qu0
