i cant remember if i used wrx seals or evo seals but i got them from autozone and one set worked.
are you using the kia manifold or the evo manifold now?
I'm fitting WRX Pink 565 injectors in but the lower seal seems to be a little sloppy, is this normal for other people because the stock galant ones fit perfect, is there any other lower seals to install, that fit snug? i bought new seals for an evo8. i dont want any leaks to happen when i go under boost,
<a href="http://s40.photobucket.com/albums/e202/duh2150/?action=view&current=crownvicbannerpart3.jpg" target="_blank"><img src="http://i40.photobucket.com/albums/e202/duh2150/crownvicbannerpart3.jpg" border="0" alt="Photobucket"></a>
now that i think about it im pretty sure i used evo lover seals with the blue wrx injectors
I just took off the Hyundai manifold and replacing with evo 8 manifold I was using modified 8g seals before, I had to push them in the Hyundai manifold so it sealed around the injectors good now that the seals fit perfect it doesn't seal as good I'm going to bolt the fuel rail down to it to see if it seals better around it
Sent from my SAMSUNG-SGH-I997 using Tapatalk
its fine i got bigger problems for some strange reason the injectors dont reach, even without the spacer, im kinda confused
What fuel rail are you using? You gotta use the EVO rail because the mounting flanges are smaller on it.
I'm using a evo 8 one, I'm confused because I keep seeing pictures with the same evo8 rail and spacer and the injectors are reaching the evo injectors must be like 1/4 inch longer
That's weird I've got the EVO rail, intake manifold, and the blue erx injectors they fit fine ill take a picture after work and see if anything is different.
I got them to fit I had to file down the mount with no spacer could you post up a picture ill post mine when I get home, it fits now, I still want to know why it doesnt fit like its supposed to
no spacers, only why i could get them close to fitting
oh your using an ams fuel rail? that may have something to do with it. i'll upload my pictures today
I tried the oem evo one also I had on my car and it didn't work either so I just put the Ams one on I had to do slight modification to get the back of the rail to not hit the lip of the manifold the spacers would have made it a direct fit if the Injectors reached
