Thread: Disabling the horn beep with keyless entry?
Showing results 1 to 4 of 4
    Is there a way to disable the horn beep with the keyless entry lock? I've searched and found nothing. I know on 2004 and up it's programmable but not sure on 2003. The guy I talked to at the dealer wasn't sure either. I know if I hold the door open and press the lock button there is no horn beep but I don't always do that.
    Any thoughts?
    This may work!!
    '00 Patriot Red GTZ --> JDM'ed... 5 Speed... ...
    05-03-2007
    Socal/Central Coast
    3,803
    it should tell you how to do it in your owner's manual in the car.
    I found this info on this for a 3G eclipse and thought I would try it, and it worked for my 2003. Not sure about other years.
    Horn Chirp Activation/Deactivation
    Press and hold the LOCK button on the transmitter for 4 sec and release and then 10 seconds andwhile the LOCK button is being pressed after 10 seconds is up press the UNLOCK button.
    Release both buttons.
    This was after the dealer told me it's not possible!
    I don't have a way to upload a video I did showing how to do it and that it worked but when I do I will get it uploaded. Hope this helps if anyone else is wondering.
    I did this because I have a super loud horn that I disconnected until I figured this out.
    - Sent from my iPhone using Tapatalk
