Thread: Projector Fog
Showing results 21 to 40 of 59
    I was looking at these of multiple Ford (Mercury, Lincoln) vehicles, Since they are used out in the open on those cars I thought we can use these on ours too, and for $100 bucks a pair not bad.
    http://www.ebay.com/itm/New-Pair-Fog...item3a6b1070b8
    02-08-2012
    Hackensack NJ
    1,146
    Icon3
    WOAH! Really? It fit perfectly? I def wanna do this mod...what's the dimensions of the projector on the mazda. I was gonna do the blazer foglight mod but like it was mentioned it's too small and I wouldn't know how to fill in all the extra space plus the bezel as well.
    Usually such a retrofit requires customization so no it won't just bolt right up, but worth your time and effort in the end if executed properly.
    02-08-2012
    Hackensack NJ
    1,146
    Ok that sounds good and I bet it is worth it, I just don't know how to go about doing it. Here's the link for what I was looking at.
    http://www.theretrofitsource.com/pro...roducts_id=249
    Right the blazer fogs, those are designed to be mounted with their included hardware. For someone trying it out for the first ti,e it's probably the best way to go.
    02-08-2012
    Hackensack NJ
    1,146
    Yeah I'm def thinking about getting those, I just don't know how to fill up the gap it's going to leave since it's small
    12-13-2010
    Brooklyn, Maryland
    4,643
    Vic, I'm definitely gonna run some Fusion fogs, they handle HID's better than Blazers, the bowl burns on Blazers with HID's in them. HIDPlanet has a bunch of threads about it, and one member (Jp7 I believe) seels them for $75 on the regular.
    -Greg
    02-08-2012
    Hackensack NJ
    1,146
    How big are the fusion fogs...and btw how big are our stock ones?
    I found those a while back. The member on hidplanet sells the fusion fogs?
    02-08-2012
    Hackensack NJ
    1,146
    Idk. What's the diameter of our fogs so I can look for replacements. Does anyone know?
    12-13-2010
    Brooklyn, Maryland
    4,643
    IDK the diameter, but it's not as simple as pop our stock ones out and throw these Fusions in, it's gonna require some fab work, and that's where the fun comes in.
    -Greg
    02-08-2012
    Hackensack NJ
    1,146
    Oh yes I know. It looks the the fusions are about 3-3.15 inches. I think ours might be four but not sure. Let's see if I can do some research
    02-08-2012
    Hackensack NJ
    1,146
    You know what...I think ours is 3 inches too
    02-08-2012
    Hackensack NJ
    1,146
    I measured the stock diameter of our fogs and they're 4 inches. I guess if you put like a 3 inch one in it'll fit since some need room for mounting hardware
    Btw, I'll ask my buddy but he has I believe aftermarket 06 corolla headlights and he said he'll bake it for me and take out the projectors so I can retrofit it. Does anyone know if it's a good size?
    10-05-2008
    Grand Rapids Michigan
    1,141
    Quote Originally Posted by JDyal View Post
    The Lens ??? No way lol, The lense is most likely going to be a 2in just like the blazer. You are going to have to some cutting to put a fusion in too, they are kind of funky as far as mounting goes.
    02-08-2012
    Hackensack NJ
    1,146
    No the lens is four I measure it. Blazers is two and so small
    02-08-2012
    Hackensack NJ
    1,146
    Unless it's just me since I have an 03 8gb...maybe that's it
    all gs have the same fog just the baking is different. i used fogs from the 99 g on my 02 , just the fogs
  19. #39
    10-05-2008
    1,141
    I quoted your part about the fusion, it has a 2in lens
  20. #40
    02-08-2012
    Hackensack NJ
    1,146
    Quote Originally Posted by johnygezony View Post
    Oh ok thanks I knew it was small. Say I was to get the Fusions or blazers...what's a good way to fill up all that space? My buddy said mesh but i like the bezels and wanna keep them since it matches the grill unless I get like the lancer type mesh.
