Thread: Galant GTZ - hitch / towing
Showing results 1 to 7 of 7
    kcarel
    Looking to move a 4 wheeler on a single axle small trailer. All I got is my galant. Obviously, no tow package but the load is relatively little and I do have a v6. not sure if there's a hitch out there that is common. Any suggestions/experiences?
    Thanks.
    kcarel
    Correction...GTZ...
    :cough: rent truck :cough:
    Why rent a truck if you plan on moving it a few times?
    For the weight of the trailer and 4 wheeler, you probably only need Class 1 hitch.
    Curt Hitches and Rigid Hitch (based out of Minnesota) are both good choices.
    http://www.etrailer.com/Trailer-Hitc...cleid=20016342
    That one is a direct bolt on.
    MEh...I was thinking about possible damage to the transmission.
    A trailer is going to be about the same as having 4 really fat chicks in the car with you. Can the transmission handle it? Yes. Should you drive it with that weight and at WOT constantly? No.
    I think the fat chicks are heavier. LOL. But I see what you mean.
    Wouldn't a rental be cheaper than $200 bucks though?
