Thread: TPS pinout help!!!!
Showing results 1 to 7 of 7
    BlackBeauty
    Icon5 TPS pinout help!!!!
    Anybody know what the throttle postion sensor wire pinout is? I'm installing a jetchip vforce module and it wants me to tap into the white/red wire..... here's the kicker there's two white/red wires going into the tps harness. If anyone has installed one of these help would be greatly appricated!!!!!
    08-04-2003
    NY
    4,344
    Im not that familiar with 9g's, when you say there are two white/red wires, are they identical or is one white with a red stripe and one red with a white stripe?
    99' Galant ES
    4G64/63T
    AEM EMS
    BlackBeauty
    Good question, the pinout chart says red/white. Does that mean red with white stripe?
    TGC Lifetime Patron Palmz's Avatar
    04-14-2011
    Iceland
    533
    Quote Originally Posted by BlackBeauty View Post
    in most cases yes.
    2001 Galant 2.4 USDM
    Old ones
    2X BMW E34 Blaaackkkk
    Isuzu Trooper mountain spec
    BlackBeauty
    Thanks Pernir! Will post once connected!
    08-04-2003
    NY
    4,344
    Quote Originally Posted by pernir View Post
    in most cases yes.
    +1 ...yep
    99' Galant ES
    4G64/63T
    AEM EMS
    BlackBeauty
    Installed.... And Im glad I didnt spend my own money... I can feel a little more pick up and the shift points seem to be firmer but its really just a on board multi-meter. Snake oil not worth 2 bills....I think I'll stick to actual performance mods from now on. Thanks for the help guys.
