Thread: General Auto wiring and electrical info
Showing results 1 to 5 of 5
    TGC Regular bgood12's Avatar
    07-17-2009
    From Dallas, Texas in Topeka KS
    554
    I have posted this before, but in general this site has helped me to understand everything about my galant and other cars i have worked on. So I think any newbs that have questions might be able to use this.
    Most of these links are from a series called How to electronically modify your car. But these are only a fraction of the info this site ha. www.autospeed.comI use it a lot.
    Relays, what they are and how to use them
    Another explanation of Relays
    Salvaging Electrical Parts
    Understanding Electrical circuits
    Using A Multimeter
    05-03-2007
    Socal/Central Coast
    3,803
    Very helpful write-up on relays. I took several electrical engineering classes but we never covered relays, and wikipedia wasn't very helpful last I recall.. though the last time I looked it up was before I took those electrical classes.
    +rep
    ps: you get those wheels on yet?
    TGC Regular
    07-16-2006
    Cocoa, Florida
    791
    really beam what school did you go to? i would think it would be covered for sure
    nice write up
    <a href="http://s40.photobucket.com/albums/e202/duh2150/?action=view&amp;current=crownvicbannerpart3.jpg" target="_blank"><img src="http://i40.photobucket.com/albums/e202/duh2150/crownvicbannerpart3.jpg" border="0" alt="Photobucket"></a>
    05-03-2007
    Socal/Central Coast
    3,803
    Quote Originally Posted by duh2150 View Post
    nice write up
    I go to Cal Poly. I'm an Aerospace engineer so our main focus isn't electronics.
    First one was a beginner's class about circuits: KCL, KVL, node voltage, thevenin/norton, DC, AC, transformers, capacitors, etc.
    Second one was a more advanced "electronics" class: transistors, diodes, op-amps, rectifiers, analog-digital conversion, binary and hexadecimal representations, etc., and how to understand, interpret, and calculate their function in circuits.
    Learning about relays would probably fall in some area between those two classes, because the second is a fairly high level class and focuses on digital circuitry, where you would never really need a relay since it is for high powered applications.
    05-14-2010
    Coachella, CA
    5,954
    Good stuff, They should sticky so it remains on top.
