Thread: 95 Galant code 63
Showing results 1 to 3 of 3
    Icon5 95 Galant code 63
    My check engine light comes on after cruising on the highway for about 10 mins. It also has this problem where if you give it a lot of throttle (from a stop), the engine will bog until it gets to higher RPMs. Some say this is the distributor. In any case, I scanned the codes using the voltmeter and counting the sweeps. I have code 63, and I can't a description anywhere. Anyone have a list? Thanks.
    there's no code 63. These are all the codes:
    11 Oxygen sensor fault.
    12 Airflow sensor fault.
    13 Intake air temp sensor fault.
    14 Throttle position sensor (TPS) fault.
    15 Idle speed control (ISC) motor position sensor fault.
    21 Coolant temp sensor fault.
    22 Crankshaft position (CKP) sesnor fault.
    23 Camshaft position (CMP) sensor fault.
    24 Vehicle speed sensor (VSS) fault.
    25 Barometric (BARO) pressure sensor fault.
    31 Knock sensor fault.
    32 MAP sensor faulty.
    36 Ignition timing adjustment signal fault.
    39 Oxygen (O2) sensor fault.
    41 Injector(s) fault
    42 Fuel pump fault.
    43 EGR fault.
    44 Ignition coil (cylinders #1 & #4) fault.
    52 Ignition coil (cylinders #2 & #5) fault.
    53 Ignition coil (cylinders #3 & #6) fault.
    55 Idle air control (IAC) valve position sensor fault.
    59 Rear Oxygen (O2) sesnor fault.
    61 Transaxle control module torque reduction signal fault.
    62 Variable Induction control (VIC) valve position sensor fault.
    Even the closest code 62 is for the MIVEC 6a12 Euro and JDM Galants and not applicable for the US models.
    You counted the flashes wrong. Do it again
    Thanks for the info. I don't know man... it's kind of hard to mess up. I have six long pulses followed by three shorter ones, and it constantly repeats itself. Sucks.
