9006 bulbs are single filaments, and are usually used in split (seperate) headlight setups. Your high beams shouldn't be affected.
Also, if you're not using projectors...DO NOT use 55W, you'll blind everyone on the road.
I am going to purchase a 6k 55w 9006 kit. But i noticed the 9006 does not have the Hi/Lo option. Will this cause my high beams to not work?
Any help is appreciated.
Ok thanks, i appreciate it! and also thanks for the heads up on getting 35w.
