Thread: Does this happen to anyone else?
Showing results 1 to 20 of 22
    00GTZ00
    I noticed today that when I am doing about 70-80 mph my hood starts to move up and down about 1/8" just in the center of the hood though, not on the front or back. does this happen to anyone else?
    Behind YA! (NY)
    727
    what the i do that on a daily basis and have never noticed this, sounds very very weird.
    - Atba
    Baltimore, MD
    2,848
    Yea I agree with Atba... I've never seen my hood move even at top speed. Better check your latch mechanism for wear. You wouldn't want that thing flying open at 80 MPH.
    Chip
    (Paint Code: Porsche LC9Z)
    by center in which direction do u mean? the center of the front. or the center of the back or the center of the hood period. if its dead center. might wanna check the hindges too
    00GTZ00
    ok if you asre sitting in the drivers seat you know how you can see the left side of the hood? right next to the drivers side fender? this is were I noticed it. Only because I have pollon on my hood (which is yellow) so I had a contrast color from the rest of the car. ( the fender is black and the hood has a tinted yellow to it) And when I was driving I noticed that the drivers side of the hood, closest to the top center of the drivers side fender, was moving about 1/8" of an inch or so. Does this make more sence to everyone? I could not see the pass side so I do not know if that side is also moving...
    I guess I will have to check the bump stops or something....
    yea, thats what i thought. check ur latch and ur hindges, tahts about the most u can do. remember that area would be the weakest part i guess. its not being held in by anything but the hood latch all the way in the front and the hindges in the front. you might want to check the fender too. could be that could be flimsy for some reason. but i doubt it...
    00GTZ00
    cool I will check the latch and everything before I leave work... Thanks for the help!
    Yeah, check the latch and I also suggest that you screw the rubber hood stops UP (and make sure they are there) Raising them should put some tension on the hood when its closed..
    Senior TGC Member
    2,175
    My hood does that, but it's damaged. Doesn't sound normal though.
    Tiptronic
    i never paid much attention umtil now. i will definitely be lloking tomorrow when i go to work
    Mine does it also at about 65-75 in that area
    STEPHEN
    2000 GMC K2500 4x4
    2004 Chevrolet Tahoe 4x4
    Tiptronic
    Quote Originally Posted by Wintergalant
    could this be happening more than we know, and we just arent seeing it. i mean we have had problems in other areas. this wouldnt come as a shock
    ewgiii
    hmm... idk. i havn't noticed it, but my car's going into the shop 2morrow for my squeeky brakes( :? for the second time on a car w/ 8000 miles ). but i'll be sure to check it b4 i take it there if i get a chance, maybe tonight. who knows, mitsu might know somethin about it.
    This is normal. I used to wonder the same thing when I left here to Concord. There is a highway here with very high winds. I used to watch the hood flap like my CF hood would normaly. I thought it was weired too until I just keeped noticing it but only on that highway. You can see a little movement at high speeds.
    www.edelhausrottweilers.com
    the hood flexes a bit...that's normal.
    GREEN is the new BLACK
    09-22-2002
    Kissimmee, FL
    1,495
    I have never seen my hood do that, even when i have the Eribuni racing hood... I say check the hinges, could be loose..
    you got a good eye. an 1/8 of an inch is small...
    00GTZ00
    Quote Originally Posted by PinoyESV6
    It was all thanks to the pollen thaqt I had on my hood. it gave me a contrasting color to compair the hood to the fender
    09-22-2002
    Kissimmee, FL
    1,495
    Quote Originally Posted by 00GTZ00
    Damn, thats a really good eye.. you must eat a lot of carrots, i got glasses and i wouldnt have seen that mess..
    MnGalant
    I was looking at mine today well i was doing abot 65 and it was moving up and down. I got home and went to the front of the hood and pulled up and down with the latch still hooked and i could move it about an 1/8 ti a 1/4 of an inch.
