Thread: DOHC most aggressive "stock" cams?
Showing results 1 to 20 of 20
    Does anybody have the specs on the dohc cams? I am installing valves today but want to put the most aggressive cams in with parts I have. I am using a 1g head with a modded distributor and staying na. I have or can get locally and cheap a set of GS cams, 97 Sonata cams and 1g na cams. I am thinking the GS cams are 264's and likely the best ones to go with but wanted to double check first.
    Yeah the gs cams are the more agressive cams.They are an upgrade compared to the other two.
    The G stamped cams are more aggressive 264/260 I believe, but they are rare and hard to find.
    Here's more info on the GS specs.
    https://www.thegalantcenter.org/showthread.php?t=13984
    According to that info the exhaust should be a h or g but both of mine look like k up front close to the cam gear.
    08-18-2004
    Charlotte, NC
    1,029
    The GS cams are somewhat like a weak HKS 264/272 cams or borderline HKS 264 cams but with very small lift.
    1994 GS FYI
    DSM/CSM Manuals
    08-13-2008
    Waterbury, CT
    3,331
    on my cams they are L stamped cams. i cant find anything on them
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
    That is weird i wonder if they are upgraded ones.What do the eclipse ones have on them?
    08-18-2004
    Charlotte, NC
    1,029
    Use a digital caliper and measure the cam lobes. If the cam height falls in the catagory of the GS cams then the duration should be the same as the GS cams.
    Or just purchase some DeltaCam 264/272 cams.
    1994 GS FYI
    DSM/CSM Manuals
    08-13-2008
    Waterbury, CT
    3,331
    These L cams are from a 94 GS so I think they would be around there but I didn't know if it meant anything specific
    2014 Lancer Evo GSR
    08-18-2004
    Charlotte, NC
    1,029
    could be a revision version..idk
    1994 GS FYI
    DSM/CSM Manuals
    08-13-2008
    Waterbury, CT
    3,331
    the lobe height of them are
    intake- 1.390 inches
    exhaust- 1.371 inches
    2014 Lancer Evo GSR
    08-13-2008
    Waterbury, CT
    3,331
    looking at the cams again, my cams have the L stamped where the 2g cams i have say c but on the other hand there is a little H so maybe they are just H cams then
    2014 Lancer Evo GSR
    08-18-2004
    Charlotte, NC
    1,029
    seems a bit worn, the cams: about 9.2mm lift on the intake side and 8.3mm on the exhaust. appears to be the GS cams.
    1994 GS FYI
    DSM/CSM Manuals
    08-13-2008
    Waterbury, CT
    3,331
    with my measurements and using a rocker ratio of 1.7:1 i got a lift of 8.85 intake and 8.25 exhaust. i will remeasure the intake to make sure as the exhaust is close enough
    after a closer look and not taking measurements in a hurry and inaccurately here are the specs on got
    Cam Lobe Height
    Intake-1.400 inches - 35.56 mm
    Exhaust- 1.375 inches - 34.93 mm
    Cam Lobe Width
    Intake- 1.180 inches - 29.97 mm
    Exhaust- 1.180 inches - 29.97 mm
    Cam Lift
    Intake- .220 inches - 5.59 mm
    Exhaust- .197 inches - 5.00 mm
    Valve Lift using 1.7:1 rocker ratio
    Intake- .374 inches - 9.50 mm
    Exhaust- .335 inches - 8.43 mm
    2014 Lancer Evo GSR
    08-18-2004
    Charlotte, NC
    1,029
    looks good.
    1994 GS FYI
    DSM/CSM Manuals
    I have some unresolved issues with DC. I will share my experience once they have the opportunity to make it right.
    08-13-2008
    Waterbury, CT
    3,331
    mystic, do you have any specs on what your stock ones were to compare?
    2014 Lancer Evo GSR
    08-18-2004
    Charlotte, NC
    1,029
    Quote Originally Posted by w/oarctic7g View Post
    What kind of issues?
    Galant GS
    HKS 264
    HKS 272
    1994 GS FYI
    DSM/CSM Manuals
    08-13-2008
    Waterbury, CT
    3,331
    Thank you very much. It's always good to have an idea about the cams in there now before I mess with them. So I should be around the same duration with a little more lift from what I see there. Thanks again
    2014 Lancer Evo GSR
    08-18-2004
    Charlotte, NC
    1,029
    Good. The 272/264 I have now required a bit of a heavy foot. If I went 272/280, it would be a bit unstreetable.
    1994 GS FYI
    DSM/CSM Manuals
