Thread: Advanced 5sp'rs
Showing results 1 to 3 of 3
    Bronx NYC (reppin)
    3,489
    Advanced 5sp'rs
    Well my input shaft bearing went on my trans and now that i have a new one installed, Im thinking about changing the bearing myself. My questions for those out there that have done the swap or more. Any tips on getting the trans open, gears out without a problem, and part number of the bearing. I work in the parts industry and National makes a differential bearing by the numbers 32207 and 32205. Im not too sure if they are the right ones and want to cross ref Mitsu part numbers with the numbers i have.
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
    06-16-2010
    Fort Mill, SC
    2,282
    Look it up in the CAPS system. I lost it forever ago.
    Sent from my iPod touch using Tapatalk 'cause I'm awesome...
    -Andrew
    I know that all the gears and forks and what not are fitting to the bell housing, so when you take it apart, the rear housing should slide off, after you cut the gasket off, and make sure the tranny is in nuetral before you drop it/take it apart. As for the bearing, Ill try to look it up in CAPS when I get on my laptop after work.
