Thread: Best tires
Showing results 1 to 15 of 15
    Best tires
    im running 17" Enkei RS5's / 215/45/R17, wut would u guys suggest i run? Ive noticed ppl running all different sizes.
    Senior TGC Member Skyforger's Avatar
    05-05-2011
    Medford/Long Island, NY
    2,135
    What's the width and offset of the wheels?
    -Chris-
    2003 Mitsubishi Galant ES 2.4L SOHC: "Octavia"
    2005 Honda Accord EX-L Coupe 2.4L DOHC
    Quote Originally Posted by XxGiRLaNT06xX View Post
    From the looks of the girl, her face isnt that great.. nothing a paper bag couldnt fix... amirite?
    man i really couldnt tell ya, ive been running the same size tires since i got these rims
    225/45r17
    05-05-2011
    2,135
    Quote Originally Posted by badmitsu View Post
    I'd run a 225/45 R17 or 235/45 R17 tire. Wider contact patch, and the sidewall is a bit meatier, so a bit less stress on the rims.
    -Chris-
    The Enkei RS5 was never made in anything wider than a 17x7.5, (most were 17x7"). As Reelax stated, 225/45R17 would be the recommended sizing. But you could also run these sizes:
    205/50R17
    215/50R17
    Icon6
    205/50R17
    215/50R17
    yea ive run both those sizes before, ive also run the 225/50/17 and they looked sweet.
    no wheel gap all the way around with those bitchs!
    225/50r17 is too tall. ideally u want to stay +-2% of stock circumference/diameter to maintain suspension geometry and not add undue strain to the transmission/drive-line. that's why RED did not suggest it. my first answer may have seemed very short, but it was concise.
    05-14-2010
    Coachella, CA
    5,954
    ^ NOPE first answer is still winning.
    Quote Originally Posted by Reelax View Post
    i bought 225/50t17s and that fit fine
    they will physically fit but still are a little too tall... ideally you want to stay within 2% of your original tire's rolling circumference when buying tires (for stock size wheel and/or plus sizing).
    i'll spare you the math but here are the final circumference numbers:
    since you have a v6 your stock tire was:
    205/55r16 = circumference is 78.2" (diameter is 24.9")
    225/45r17 = circumference is 78.5" (diameter is 25") = +0.4%
    225/50r17 = circumference is 81.2" (diameter is 25.9") = +3.9%
    it's not a big over size but you asked for the "best tire size" and that's the answer i gave you.
    06-13-2008
    Bronx, NY
    2,606
    225/40r18 I'm running that setup with brembo. No problem here.
    SOHC Turbo
    he has 17" wheels...
    thanks man
  15. #15
    06-13-2008
    Bronx, NY
    2,606
    ohh got it.
    SOHC Turbo
