Thread: SPECS of JUN VR4? Anybody know?
Showing results 1 to 8 of 8
    Member gian7675's Avatar
    11-29-2009
    Cebu City, Philippines
    162
    Found this posted in our local 8g thread here in the PI but nobody seems to know it's specs...
    All I know is that it's a Time Trial Car...but to what err I don't know...
    I'm hoping somebody here can help and provide it's specs and post some info about it.
    Thanks in advance!
    stroked 4g63 i beleive
    05-05-2011
    Medford/Long Island, NY
    2,135
    That massive front bumper reminds me of this:
    -Chris-
    I believe it has a 4G63 power plant. Other than that, it looks like could scoop snow during winter months :)
    Supposed to be pushing 800hp.
    11-29-2009
    Chadds Ford, PA
    2,768
    http://the-sun.on.cc/channels/car/20...5622_0010.html
    http://the-sun.on.cc/channels/car/20...22_0010_1.html
    I do not have google chrome on this computer so i cant translate it but here is some specs
    There is some more picts on this page
    http://www.trinituner.com/v3/forums/...c.php?t=158707
    Reelax's car is even on there
    11-29-2009
    162
    Wohooo!!!! Thanks for the links
    JUN VR4 conversion specifications
    Man: Can Aberdeen 23/06/2003
    Engine:
    JUN 4G63 engine 2.2 Kit (85.5mm forged piston, connecting rod, 94mm stroke crankshaft, and strengthen the crankshaft bush, 1.2mm plate top  mouth, compression ratio 8.4:1)
    JUN Stage2 272 degrees 10.8mm Camshaft Kit
    JUN Valve slingshot
    JUN Titanium Valve pie
    JUN strengthen the belt (all cars)
    GReddy TD06 25G Turbo
    Cusco Twin Plate strongly sub-
    80mm Butterfly cover
    1,000 cc Sprue × 4
    Cooling system:
    GReddy Oilcooler Kit × 2
    ARC Intercooler Kit
    SARD reserve kettle
    Koyo radiator
    Cold water tank
    Special fan
    Smoke exhaust system:
    JUN special titanium dead air hose
    JUN special banana dead air
    K & N PC965 air filter
    GReddy Type R Racing Blow Off Valve
    Suspension:
    JUN Spec Endless Zeal suspension stirred teeth
    Swift ID60 22K slingshot
    Strengthen the equipment:
    Qiantaxiangba
    Nine-style roll cage
    The entire vehicle to strengthen the bottom bear
    Brakes:
    AP Racing six piston calipers (front)
    AP Racing front and rear braking force distribution control
    Brembo two-piston calipers (rear)
    Evo. Ⅵ brake master cylinder
    Wheel combination:
    SSR Type C wheels (18 × 9.5 +30 Offset)
    Yokohama Slick Tire (250/650R18)
    Electronic equipment:
    GReddy Mechanical Plumbing valves
    GReddy Speed ​​Limiter Cut
    HKS F Con V-Pro PC
    HKS Twin Power
    Max Racing Electronics dashboard
    Other equipment:
    JUN engine oil cap
    JUN 3D GT wing
    JUN surrounded the whole car
    JUN head 
    5 Zigen  ring
    5 Zigen gear stick head
    Corbeau bucket seat
    Sabelt four-point seat belts
    Best motoring has a video on it. I remember seeing it on the front page with a evo!
