Thread: Help removing caliper braket
Showing results 1 to 10 of 10
    I am trying to do this on '06. I have tried to hummer a ratchet on the 2 nuts that seem to be holding the braket. Also tried using penetrating oil and letting sit for a while but it didn't work. Could someone help me?
    are you talking about the two nuts holding the caliper? if so, try extending the the ratchet handel with a pipe. make sure you got the right sze socket so you wont strip the nut.
    No. I am talking about the bracket that stays on the rotor after you remove the caliper.
    theres nothing holding onto the rotor. the caliper bracket is bolted to the knuckle.
    Take your half inch ratchet with a 17mm socket IIRC. Find a long pipe, something like the handle on a hydraulic jack, put your purse down and it will break loose. hopefully you havent stripped the nut yet.
    Also, if you have a good impact gun, it will come off like butter.
    Jigz-TGCIL Sosick Motorsports
    You are right the bracket is not attached to the rotor. And I have tried with ratchet that has a very long handle (20" aprox). There is no clearance for more. And the nuts aren't stripped yet. Any other ideas. Maybe I'm trying to take out the wrong nuts.
    get a 17mm box wrench and a hammer. that will solve your problem.
    http://vids.myspace.com/index.cfm?fu...ideoid=2799274
    A filipino's number one dream is to own a car before anything else. In the philippines, most private car owners consider their vehicles as an extension of their home but with one differrence: a home is where his wife cooks while a car is where his girlfriend builds a fire. Hmmm...
    05-05-2011
    Medford/Long Island, NY
    2,135
    Leverage is your greatest ally.
    Six point box wrench, and a looooooong pipe that fits over the wrench, then crank lose. =]
    -Chris-
    12-13-2010
    Brooklyn, Maryland
    4,643
    Quote Originally Posted by Skyforger View Post
    This all day, turn the wheel so that you get as much space as possible, and crank that joint!
    -Greg
    05-05-2011
    2,135
    I dunno how many people I've seen fuck up bolt heads with 12 point wrenches and sockets. lol
    -Chris-
    i once bent my caliper pulling so hard on it, u live u learn!
