Thread: Get rid of rust, For Good!
Showing results 1 to 3 of 3
    Saw this on evom,
    http://www.importtuner.com/tech/impp...ion/index.html
    http://calyxmanifold.com/products/products.htm
    Ths stuff looks like it works great, also you can use it on any bare metal surface.
    Looks like it's worth a try, especially if you don't have a heat shield anymore.
    02-08-2012
    Hackensack NJ
    1,146
    You guys didn't use this yet did you?
Tags for this Thread
