Thread: Toyota 2JZ-GTE Engine on 8G Galant
Page 13 of 14 FirstFirst ... 391011121314 LastLast
Showing results 241 to 260 of 273
  1. #241
    Mother...of..God...
    THAT IS SIIIIICK!!
  2. #242
    Mother...of..God...
    THAT IS SIIIIICK!!
  3. #243
    The inevitable happened, I broke the diff
    Actually it lasted more than I expected
    So, here is the broken 8G VR-4 AYC Diff
    The Replacement. An 8G VR-4 non-AYC Diff. Because its housing is made from steel unlike the AYC diff which is made from aluminum, it will hold some power
    Non-AYC Diff vs. AYC Diff
    While we're at it. Lets go LSD
    Cusco RS 1.5 Way LSD ( Evo I to IX )
    Open diff vs. LSD diff
    LSD ready to go
  4. #244
    12-13-2010
    Brooklyn, Maryland
    4,643
    That is dope! This car is awesome!
    -Greg
  5. #245
    03-12-2012
    Manvel Texas
    1,171
    Sswweeetttt!!! I can only dream..... This is to sick!!!
  6. #246
  7. #247
    08-26-2007
    L.I.N.Y./ Rockville MD
    1,148
    damn for a minute there I thought that was a transfer case, that thing is BIG!
  8. #248
  9. #249
    Why the LSD was not done sooner on such a build is beyond me =P
    I'm sure you will notice a significant difference!
    Eclipse GT 5 spd swapped
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
  10. #250
    The AYC diff wanted to come out and say hello.
  11. #251
    Re-tuned the G and solved the glowing manifold problem which was caused by improper ignition timing so now she has 600 HP @ 22 PSI of boost
  12. #252
    03-12-2012
    Manvel Texas
    1,171
    LIFT OFF!!!!! Shall we!!DAAAMMMMNNNN!!!!!!
  13. #253
    Put on your helmets this might be a bumpy ride!!!!!
    I dont think i have seen a Galant do those numbers before
    Sent from my LG-LS970 using Tapatalk
  14. #254
    This makes me want to turn my engine sideways and go to town =P
    Not that I haven't told you before, but this is awesome! 600hp
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
  15. #255
    And making quite a noise
  16. #256
    TGC Regular djhah's Avatar
    03-15-2010
    nashville, tn
    505
    So sick!
  17. #257
    Bought Toyo R888 Tires
    And went to try them
    And I got massive wheel spin in the first 3 gears. I got to figure out something
  18. #258
    03-12-2012
    Manvel Texas
    1,171
    Heat them up, makes them sticky.
  19. #259
    Gonna need a wider tire. Greddy spins his 255's with half the power this beast makes.
    Looks like that pass was about 15 seconds, the wheel spun did affect you alot as well as track condition. For best time you are gonna want slicks, the car needs taming its like a hound from hell the cure for this is lots and lots of seat time. Very impressive build.
  20. #260
    Yeah because Greddy's FWD car is comparable to a RWD car.
    All in all this car is pretty cool but it will never really perform like one would think of given the connotations of a 2JZ. The rear suspension is multilink, it's made for AWD and handling and it's old technology. You're putting more power through it than it can handle, while it may not break into pieces yet the hardware is physically too small to handle it. It'll flex, move around and result in pitiful traction all the time and poor handling. Beyond that you can't get wide tires back there. 235 is too small for any car that makes power short of a go kart. Even more than that an 18" wheel doesn't support straightline traction either. You need a tall sidewall for that.
    If you ever do start to hook then you'll begin breaking things. Control arms, axles, and burning up rear differentials like crazy. Evo guys break all those things with the same power at all four wheels... The fact is spinning is the only reason it hasn't grenaded yet.
