Thread: Toyota 2JZ-GTE Engine on 8G Galant
Page 4 of 14 FirstFirst 12345678 ... LastLast
Showing results 61 to 80 of 273
  1. #61
    wowwww nice and in the short time u did it in wow
  2. #62
    07-12-2007
    SoCal
    4,632
    Awesome! Now come to Cali and do mine!
    JDM Zenki Conversion
  3. #63
    04-29-2009
    Holyoke,Massachusettes
    3,600
    Wow
    FreakyDeaky
    2kG 6g72/74 5 speed
  4. #64
    Drive shaft to be installed today hopefully
  5. #65
    My pleasure
  6. #66
    I can just imagine RB26DETT 8G.
  7. #67
    08-04-2003
    NY
    4,344
    Nice man. I cant wait to see that thing on a track
    99' Galant ES
    4G64/63T
    AEM EMS
  8. #68
    TGC Regular Da_Prodigy's Avatar
    01-29-2010
    Elgin,IL (Chicago Suburbs)
    593
    Wow I'm truly impressed
  9. #69
    This is a great build. Nice job!!!!
    The key to Immortality is first living a life worth remembering.
  10. #70
    Drive shaft arrived
    Installing ...
  11. #71
    Hope it don't break. What material did they use?
  12. #72
    looks pretty thin
  13. #73
    ^ I was gonna say that. Didn't wanna make my post come off the wrong way, but it if it is made of strong quality metals, should hold up.
    OP, did shop tell you the material? Or Give you any numbers like how much torque and HP it's rated at?
  14. #74
    TGC Regular eclipsh's Avatar
    09-06-2008
    SW Colorado, USA @ 7600 ft
    533
    It isn't just torque and horsepower, it is rotation speed, as I found out the hard way. With the gear ratio of the current rear end and the tire height that thing will be spinning really fast at 60-80 mph. My drive shaft failed at around 75 mph and it scared the piss out of me (thankfully not literally).
    That said, this one has to be shorter than the one I used. It also looks like the diameter to length ratio is worse though. Without using a driveshaft calculator I wouldn't wager a guess as to it's viability. Did the shop making it know how fast it would spin or other details?
  15. #75
    08-04-2003
    NY
    4,344
    Yikes. That driveshaft looks small. What material is it made from? Plain steel? Chromoly? Do you know the wall thickness? Judging by the floor tiles which are commonly 12"x12" that shaft is about 5 feet long. I am using 3.5" diameter aluminum on a shaft thats about 8" shorter and only delivering half the engines power to the rear. I would be very very cautious using that shaft you have there. Make sure you run a safety loop.
    99' Galant ES
    4G64/63T
    AEM EMS
  16. #76
    Drive shaft installed. ( Thick enough to handle the torque and no idea about the rotation speed calculating )
    Any way, clutch pedal installed but clutch master cylinder jammed.
    Looking for replacement.
    Work temporary paused.
  17. #77
    it is 135 cm. It is thick from the iside. It is galvanized steel. It could be replaced easily if it fails. Im trying to get the car running at the first place. Thanks a lot everyone. Wish me best luck
  18. #78
    05-05-2011
    Medford/Long Island, NY
    2,135
    They didn't tell you what the driveshaft is made from?
    *edit*
    you posted right before me. lol
    -Chris-
  19. #79
  20. #80
    What sould I do ?
    Make it thicker ?
    Make it aluminum or steel ?
    Calculate the rotation speed ?
    Cut the car in half and make it Coupe and so the drive shaft will get shorter !
    Thanks
