Thread: Toyota 2JZ-GTE Engine on 8G Galant
Page 5 of 14 FirstFirst 123456789 ... LastLast
Showing results 81 to 100 of 273
  1. #81
    Yikes. That driveshaft looks small. What material is it made from? Plain steel? Chromoly? Do you know the wall thickness? Judging by the floor tiles which are commonly 12"x12" that shaft is about 5 feet long. I am using 3.5" diameter aluminum on a shaft thats about 8" shorter and only delivering half the engines power to the rear. I would be very very cautious using that shaft you have there. Make sure you run a safety loop.
    it is 135 cm. It is thick from the iside. It is galvanized steel. It could be replaced easily if it fails. Im trying to get the car running at the first place. Thanks a lot everyone. Wish me best luck
  2. #82
    TGC Regular eclipsh's Avatar
    09-06-2008
    SW Colorado, USA @ 7600 ft
    533
    LOL, we're not trying to be haters, it is a great build. We just want you to be safe. When a drive shaft goes out it can be very dangerous. I was lucky mine didn't hit the gas tank or get under a tire to spin or flip my car. Mine bounced and lodged between the car body and the exhaust. It beat the hell out of the unibody in the process, leaving a big dent in the passenger front floor pan. It struck right at the corner where the steel was strongest too so there was a lot of force behind that hit.
    Wall thickness is much less important than drive shaft diameter vs. length. A quick Google search for driveshaft calculator pulled up this one:
    http://www.wallaceracing.com/driveshaftspeed.htm
    With a 53 inch shaft at 2.5 inch diameter you'll handle plenty of torque. The problem is the critical speed. I don't have the calculations lying around for what our drive shafts spin at but I know that it was up around 5-6K rpms at 65-70 mph. If you drive at or above the critical speed of a driveshaft for long harmonics can cause it to start wiggling and tear it apart. They have some pretty good explanations on the site. To calculate your drive shaft speed you need your tire diameter and rear gear ratio. I'm sure you can get that stuff off the web quickly too.
  3. #83
    Quote Originally Posted by eclipsh View Post
    I love you all guys
    I really appreciate your support
    Just seeking your advice ( I'll chk the website later after I get some numbers )
    Thanks in advance
  4. #84
    My advice is when you have it running, you bring it to me to test...permanently... :)
  5. #85
    I can just imagine RB26DETT 8G.
    im saving money cause thats what i want to do!!
    (and obiusly get a nissan gtr 34 v specII )
    hahaha
  6. #86
    I've decided to temporary keep the current drive shaft.
    Since this engine has HKS 272 Cam, Siemens 650cc Injectors, Brian Crower Valves/Springs, ...
    It must be tuned b4 so we can run it safely.
    For now, I will start with Idle tuning.
    Heading to the Tuning Shop
    AEM EMU Seriers 2
    AEM Boost Solenoid
    AEM 3.5 Bar MAP Sensor
    AEM O2 Sensor
    AEM All-in-one Gauge
    To be continued
  7. #87
    08-04-2003
    NY
    4,344
    Good choice with the AEM. When you setup your boost settings using the boost solenoid make sure you tune the boost controller settings on the street. From my experiences it's more accurate than the dyno since the dyno can never duplicate driving loads exactly as they are during real driving
    99' Galant ES
    4G64/63T
    AEM EMS
  8. #88
    Damm i want to see thar car runing now!!!
  9. #89
    Thanks Brian, I'll keep that in mind
  10. #90
    06-16-2010
    Fort Mill, SC
    2,282
    I'm drooling
    Sent from my iPod touch using Tapatalk
    -Andrew
  11. #91
    Wow this is gonna be sexy :D
  12. #92
    Car went out of the garage today at last
    Check http://www.youtube.com/watch?v=9-RCyOJTmDc
    It is a real RWD Galant
    as ( Stewi ) said b4, Im gonna say: First 8g RWD swap. Completed.
  13. #93
    12-13-2010
    Brooklyn, Maryland
    4,643
    Congrats!! That was fast work, incredible stuff man.
    Incredible what these guys are doing with these Galants lately.
    -Greg
  14. #94
    Poor Galants, I feel sorry for them ^_^
  15. #95
    12-13-2010
    Brooklyn, Maryland
    4,643
    Quote Originally Posted by Samman View Post
    I feel sorry for the fool that pulls up next to one of these super G's and thinks he's got an easy win. That's serious pwnage taking place!
    -Greg
  16. #96
    11-18-2009
    Buffalo, NY
    1,758
    Congrats man!!
    - Chris -
    DRL Delete
  17. #97
    08-04-2003
    NY
    4,344
    Nice!!!
    What did you do for the front hubs? Are they still the AWD hubs and you just removed the axles?
    99' Galant ES
    4G64/63T
    AEM EMS
  18. #98
    07-12-2007
    SoCal
    4,632
    AWEsome!
    JDM Zenki Conversion
  19. #99
    Love it! Congrats man, sounds like a success to me.
    Eclipse GT 5 spd swapped
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
  20. #100
    Congrats man. It's really sick. You should upload a couple more vids on youtube!!!
