Thread: First USDM 8g AWD swap. Completed.
Page 1 of 4 1234 LastLast
Showing results 1 to 20 of 78
    08-04-2003
    NY
    4,344
    First and foremost I have to give special thanks to a few people who gave me alot of needed info and help over the phone while doing this swap. Cali, BostonHatcher (club3g), Balla4880 (club3g). Cali I actually took his back seat out and called me to walk me through the wiring of the awd fuel sending units. He literally stayed on the phone with me while I soldered the wires and checked everything. Also big props to Roman (Goosey2099) on completing the swap as well, we were going back and forth to see who would finish first. I just ended up getting luckier and finished it first. He did it in far less time though since he had access to a shop and lift and I was doing it on my back in the garage. He also did a complete engine/tranny/awd swap all at the same time which was way more involved in terms of wiring and fabricating is concerned.
    Well I was gonna hold off until after MOD to post pics and what not, but since Angel started posting some teasers of Roman's swap, im gonna join in. The car has been swapped now for about 2 weeks. I will be honest, I was really trying to get the car done in time for the TGCNY meet back in July but when that didnt happen I kinda stepped away from it for a while mostly because I was sorta tired of working on it and I was working crazy hours and wanted to spend some more time with the wife and daughter. On top of that, I was buying a house and moving all at the same time.
    With that being said, along the way I did some things that I thought were "right" or "correct" that ended up being not to my liking. For example, I made an adapter to bolt to the rack to extend the shaft to attach to the column. Good idea except it needed to have a u-joint on it and due to the factory column having a u-joint at the bottom, it would bind up all the time. So I had to re-do that.
    Next, I made a bolt-on subframe brace to allow for easy removal of the t-case for service purposes. The first version of this was made of round steel tubing that ended up being too thin of a wall thickness and not strong enough. The latest version is .125" wall 1"x1" steel square tubing with .250" wall round tube mounting points. This version is plenty strong, kinda heavy at about 20lbs. With this I added another brace to the top of the subframe, nothing fancy, just a single square tube brace to prevent the two side of the top of the subframe from pushing toward each other in the center. For now, the subframe setup will stay like this, I might make a complete tubular subframe this winter, it will all depend if I can score a tig welder for a good enough price, because if I do this, I will want to use chomoly which needs to be tig'd and it will need to be mocked up on the car.
    On to the exhaust, my original exhaust "mock up" if you will call it that, was normal 3" SS round tubing like any other performance exhaust. I say it was a mock-up because I did it all myself and mig welded it and the ground clearance was terrible under the subframe. So I cut it all back up and did it over, this time I used some round to oval transition pieces to convert the downpipe area to oval where it goes under the subframe brace, this gained me nearly an inch of clearance. Its still low to the ground but I dont drive the car that often, especially not conditions where I would bottom out like that. The "new" or should I say current exhaust, is all professionally tig welded by my friend Edgar, who just happens to be a welder by trade.
    All the pics and vid's are taken on my phone. I will try to take some good pics after MOD when things calm down a bit. Im not doing a tutorial on this, I dont have that type of time available, but between the info here and on club3g, its more than adequate to get it done.
    Enough of me yappin. Two brief vids a took. Sorry for the annoying whining sound, thats my external walbro pump on its last legs, begging to be put out of its misery. Gonna swap it out later this week.
    click the pic
    click the pic
    The donor....
    rear subframe after sandblasting, epoxy primer, 2 coats of gloss black, 1 coat of clear and 2 coats of chip guard. new urethane/aluminum bushings installed.
    relocating the gas tank mounting studs. the holes are already in the body, just need to cut a window to drop a bolt thru. Once the bolts were in, I welded them to the body from the bottom and then welded the window I cut closed.
    rear floor pan cut open on the driver side to install the proper length studs,
    since the front most stud (closer to the back seat) wasnt meant to be there, you need to be able to hold it from the top while tightening the nut under the subframe. This was the quickest and easiest solution to that. Some guys on dsm tuners had fancy retainers custom machined, I wasnt gonna mess with that.
    under the factory sound deadener in the backseat, there are two square shaped areas that are just waiting to be cut open for the AWD tank sending units. I used the covers from the 2g as a template and traced it onto the floorpan and then cut it out.
    cover installed
    ballin ass FrontLine Fabrications diff cover w/bearing pre-load bolts. I had to have this...
    installed on my EVO IX rear diff
    test fitting the rear driveshaft and hanger bearing, about to weld the hanger bearing bracket to the floor pan
    firewall cut for clearance. this is a tedious process. This was the 2nd day of cutting. I ended up removing even more of this a little further back and actually cut straight thru into the car and made a patch panel in order to raise the height of the tunnel. Image where the airbag computer mounts, I had to raise that up about 1.5" Needless to say the airbag computer wont fit after that....
    lowered the steering rack mounts by 1.75"
    first subframe brace, el garbage. too thin of a wall, not strong enough, but it was good practice.
    second subframe brace, nothing else to say
    revised downpipe with the oval transitions tack welded up
    then after my boy tig'd it up. he's very good
    99' Galant ES
    4G64/63T
    AEM EMS
    Yay great job so proud of you :)
    TGC Regular P'NOYcaL's Avatar
    10-23-2009
    Bergenfield, NJ
    504
    wow good job bro! i wish i have the gift to do that kind of stuff
    ________________________________________
    -RON
    05-05-2011
    Medford/Long Island, NY
    2,135
    This, is just awesome.
    *brofist*
    -Chris-
    Great job Stewi!
    And that is some great welding!
    TGC Regular foxbrand's Avatar
    06-18-2011
    chicago suburbs, IL
    600
    WOW
    Nice Job
    Experienced TGC Member njjfudge's Avatar
    02-28-2005
    Jonesboro, GA
    1,447
    Wonderful!!!!!
    Hot Damn Brian! I am so stoked to see this! Congratulations, that's really awesome!
    Jigz-TGCIL Sosick Motorsports
    One day my 7g shall follow suit
    Me I'm a lil of both
    Rad. I want to see some numbers. (1/4 mile, dyno, ALL OF THEM)
    Damn. With a capital D.
    You going to have the undercarraige lineX'd now? I totally would. Who cares about a few extra lbs.
    12-13-2010
    Brooklyn, Maryland
    4,643
    Crazy good work bro, those welds are a thing a beauty too. Can't wait to see this!!
    -Greg
    02-07-2007
    ORLANDO
    1,599
    *faints
    this is awesommeee congrats
    08-04-2003
    NY
    4,344
    You have no idea how many times I have thought about that. If I do that, im doing EVERYTHING. I will literally take everything out of the engine bay, remove all the suspension, fuel tank, etc and put the car on a rotisserie and do it big. It wouldnt even be expensive, it would just be about 40 hours worth of work to remove and reinstall everything.
    99' Galant ES
    4G64/63T
    AEM EMS
    Fort Worth, TX
    1,418
    wow that i sfreaking awesome!! congrats!!!
    Don't do LineX.
    Do POR15.
    POR15 > *
    I love you Brian. No homo...LOL
    You and Roman are the men!!!
    TURBO= in the making.......
    12-02-2008
    Carteret & Manalapan, NJ
    1,263
    OMG...You guys are simply awesome. I give you guys so much credit in doing all this work and making it work. You are the God of all Galants! Awesome job and keep up the good work.
    08-13-2008
    Waterbury, CT
    3,331
    congrats man. glad to see it done.
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
    04-08-2010
    Springfield, Mass
    1,225
    Sick one of the best 8g's ever
    «Carlos»
