Thread: 3000GT 4pot help
Page 1 of 3 123 LastLast
Showing results 1 to 20 of 45
    3000GT 4pot help
    If any one has access to a 3000gt VR4. Could you tell me the mounting bolt spacing from the center of each bolt
    Me I'm a lil of both
    its the same as 8g/evo. i forget what is the exact measurement.
    Hmmm thought VIII had two pots these are the fours and they look as if they bolt directly to the spindle, hub ?whichever the mounting bracket mounts to see --
    nope its not a bolt on deal.
    here's the adapter bracket
    http://www.tunersnation.com/index.ph...866&parent=749
    Good shit thanks for the link
    And this will work with EBC 2g rotors??
    12-27-2005
    Charleston SC
    1,520
    Do they work with 6g vr4 rotors?
    08-13-2008
    Waterbury, CT
    3,331
    those are a fixed calliper, 2 pistons on each side. not a sliding like our single piston on the AWD dual pistons
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
    i have 4 piston 3000gt vr-4 brakes on my car. i know what it takes to put them on. and what you need. it will not be cheap. it all depends on the rotors and the deal on the calipers. i bought stoptech drilled/slotted rotors
    i spent:
    $200 both calipers
    $120 mounting bracket
    $180 Rotors
    $30 on misc items/clips/paint
    you need first gen 91-93 3000gt vr4 calipers and second gen 94+ 3000gt vr4 rotors. this is the correct combo to work with the L bracket
    [/QUOTE]
    I must say that purple is awfully sexxy
    So bigger rotors = bigger brackets?
    Quote Originally Posted by master_visionary View Post
    no. these brackets are designed to accommodate the bigger 2nd gen rotor
    I mean like some 12 inchers or so
    follow this carefully lol
    The calipers must be 91-93 calipers (1st gen 3000GT VR-4)
    The Rotors to use with the brackets are 94-99 2nd gen 3000GT VR-4. these rotors are 12.5 inches
    1st gen rotors are 11.6" or something like that. so you want the bigger rotors. i got mine for a 99 just to be sure they were 12.5".
    So you take your 1st gen calipers and mount them to your knukle using the brackets. the brackets only work for the 12.5 rotors. the bracket comes with the washer needed to space the caliper right. bolt everything on and your good to go.
    i also forgot the brake lines.
    i paid $70 for a custom SS brake lines for the calipers to work.
    1st gen rotors on top of the 2nd gen
    Aye kolio are those 2Gs stock??
    yes, they are stock sized 2nd gen rotors.
    you cannot fit anything bigger. the clearance does not allow. those rotors max the bracket out. there are only a few MM of clearance left.
    By they're not OEM what brand?
    those are stoptech. i can give you the link tomorrow when dig up the site i got them from. they are awsome.
    they are even drilled around the hub to vent more heat out!
    Quote Originally Posted by kolio View Post
    I saw that and like I said those purple calipers are sick ....what are your rears??
    08-13-2008
    Waterbury, CT
    3,331
    So the VR4 rotors are only 12.6 inches? Interesting as stock are 14 inch and the awd are 15 inch.
    2014 Lancer Evo GSR
