Thread: The fangs of the Lancer X
Showing results 1 to 20 of 38
    Hi TGC! Long ago, I hadn't been back here. I thought TGC died, on my computer the site does not open. All this time I was on Galant tuners. I want to tell You how I did fangs on his 9G. The last time my car looked like. Already passed the one year since I bought this car. I wanted to make changes in design. I bought the fangs from a Lancer X from ABC plastic. Here they are. .
    Inside fang is regiment, of which he is attached to the bumper. Take off the bumper. In the bumper have small tides, here I will install fangs.[/
    Front overhang Lancer for about 3 inches longer than the 9G. Therefore, the teeth do not fit in length. Either on the top or on the bottom. [/
    Of course, no one radius does not coincide with the bumper. I expected it, so it doesn't frighten me.
    The first step, I cut off about 5 inches from the back of the teeth and assign to the bumper. So do markup. markup need that would fangs were identical.
    Now you need to make the front of the fang.
    Fang is the stiffness and does not bend. For this it is necessary to cut off the bottom shelf. Now it easily accepts any form. It can be mounted in the bumper.
    Fang is fixed. Now it is necessary to solidify a new form.
    Now it is necessary to take a soldering iron 25w. And weld seams. The bottom shelf, which had cut off, so be welded.
    Now fang acquired a new form.
    It would now take the heating dryer. Heating temperature of 480-500C The first step cook for internal stitches.
    The next step. Should be on the outer seams to make a V-shaped trench.
    Then you have to cook for external seams.
    Further make the paint work.
    Paint.
    Set on the car. That was the way he looks now. Waiting for your comments.
    TGC Regular Redhaze's Avatar
    10-02-2010
    North Carolina
    774
    Not bad looks pretty good. nowloweritnow
    -Dirty South-
    It looks good,i would have extended them a little more in the middle though.
    i think it looks great where it is on the line of the headlights and fogs starting! wanna make another set? =P
    nice job
    uhhhh...... Whats a 9g???
