Thread: clutch line??
Showing results 1 to 8 of 8
    clutch line??
    Hey all -
    My clutch line that runs from the slave to the master is leaking. I can't find a part store that carries it. Any suggestions as to where I can find it online?
    Thanks,
    AJ
    08-13-2008
    Waterbury, CT
    3,331
    Extremepsi.com and it's the 2g ss clutch line
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
    thanks for the link! I also found the same, yet different manufacturer for the same part and at a lower price.
    http://www.jscspeed.com/catalog/Stai...se-7934-1.html
    would that work the same?
    Thanks
    AJ
    There is also one I found on dsmparts.com for a lower price
    http://www.dsmparts.com/customer/pro...&cat=57&page=1
    would any of those two be recommended also?
    Thanks again
    Here is the line that chris is talking about.
    http://www.extremepsi.com/store/prod...6&cat=0&page=1
    thanks! is that the same as the two in the links that i provided? the ones that i found are a little cheaper. are they they same?
    Thanks
    AJ
    No those ones look like they are only part of it.The one i gave you the link to goes from the master cylinder then you run it how you want down to the slave cylinder.The line i showed you will also improve the clutch pedal feel.
    08-13-2008
    Waterbury, CT
    3,331
    ask dsm parts for the length of their 2g line and if its the same as the full 2g line at extreme buy it. remember some lines are just from near the battery to the slave and not the full master to slave thats why you need the length
    2014 Lancer Evo GSR
