Well for the rear end you just get longer bolts and stack washers behind the uppr arm bracket. For the front end Uh damn I forgot the name of the company that makes them but they are direct replacements for the upper arm shafts, the swivle thing that connects the upper arm to the car. The new upper arm shafts have a bolt at the bottom that allow you to slide the upper arm itself forward or backward to adjust camber. They're for 2g eclipse so just look up a kit for the 2g eclipse.
