Thread: Lazarus
Page 1 of 3 123 LastLast
Showing results 1 to 20 of 44
    Lazarus
    Here's some better pics of my recently acquired chumpcar project: car is rock solid mechanically, which is perfect for our needs. 450 bucks!!!!!
    My friend Nial and I will slowly be making it into a chump car/HPDE car that we will use and rent out.
    bunch of hand me down cobalt race pads
    Factory hood that is not pretzel'd like ours is thanks to the previous owner when we picked up the car.
    Tractor/lawn mower/motorcycle battery
    Water pump/timing belt service
    vc gasket
    cas o ring
    Clutch slave
    OE exedy clutch wouldn't hurt
    ES arm bushings
    Bilstein HD's
    Tie rods/ends
    Ebay coilover sleeve/spring replace ebay spring with hyperco springs :)
    Rad hoses
    Heater hoses
    15" wheels
    Pax front turn signal
    HDHC roll bar/ miatacage.com cage depending on funds and where the car sits as of next spring.
    To Do:
    Inspect suspension- ball joints/replace boots & grease as needed
    PS/AC delete
    Properly gut the PS rack
    Transfer over a set of my old end links with ES bushings
    Install OEM swaybar ES poly bushings
    Re-drill stock sway bar a notch inward
    Trim factory bumpstops for new setup
    Install hand-me-down Cobalt XR3/5 pads
    All fluids
    Temp. fix on the soft top window
    Remove/reshape front bumper skin
    Fix exhaust leak
    Alignment session
    Had the whole crew wrenching on the car tonight. We made some great progress.
    Changed diff fluid with Redline
    Finished stripping the interior
    Fixed the broken passenger side door that wouldn't open
    Removed front bumper skin to reshape and asses further damges
    Removed fog lights and bumper crash pad
    Removed rear spoiler
    Purchased and installed a lawn mower battery (works great, light, and very compact)
    First oil change
    Gave the Mopar Combustion Chamber cleaner a go! This works wonders. Previous black piston tops are now sparkly clean.
    1. We applied 1/2 can through the vacuum nipple @ throttle body while idling. Car tends to bog down but no issues.
    2. Shut car off and remove plugs/wires
    3. Evenly distribute the remaining 1/2 can into each spark plug whole thoroughly coating the top of the pistons.
    4. Let sit for half hour
    5. With plugs and wires removed "crank" the car over ejecting the residue out the top of the spark plug holes. (be sure to line the top of the valve cover with old t-shirts, shop rags, etc to keep the mess to a minimum.)
    6. When no more liquid is expelled during the cranking process replace plugs and wires. Take the car on an easy drive until smoke is no longer exiting tail pipe.
    7. Change oil and enjoy what seems to be new found power along with a smoother, healthier sounding and feeling engine.
    8. repeated it on the galant as well, really works wonders, so much better than seafoam.
    we have bilsteins!!! these will be revalved for spec miata spring rates asap!!! we just saved a pile of money too haha
    Here's some more pics from tonight, I'm in the gonzaga sweatshirt with the white beanie, and my friend nial is in the tan sweatshirt
    very nice!
    any plans for the car besides usual maintenance?
    yes, it'll be stripped out, recaro seats, cage, poly bushings, spec miata suspension setup, star specs, etc.. power wise, we'll likely get an ebay exhaust and header, bump the timing, and call it good for now. The goal is to spend as little as possible for the maximum amount of fun !
    Man yall some fools lol sounds fun! Yall should definitely revive a G it would make a nice thread
    12-13-2010
    Brooklyn, Maryland
    4,643
    This is neat!! What is it up front that you guys are grinding on, the crash bar?
    -Greg
    07-12-2007
    SoCal
    4,632
    This is neat!!
    LMAO! Did you just say "neat!!"? Is this 1957 or 2011? LOL!
    JDM Zenki Conversion
    12-13-2010
    Brooklyn, Maryland
    4,643
    My bad son, dis joint here is mad tytedopeillfreshhypebeastswaggedout dawg!!
    -Greg
    03-16-2010
    Maplewood, NJ
    1,290
    Greg got swag. He can say neat all he wants!
    Greddy, fun looking project. I wish I had space around my house to do stuff like that.
    That's cool!
    Or can we still say that? Lol.
    07-12-2007
    SoCal
    4,632
    Quote Originally Posted by carl3g View Post
    That's cool!
    LMAO! Y'all crazy!
    New parts!
    free 110 dollar gauges!
    those little cars are a blast!
    -Danny
    Quote Originally Posted by deeznutz View Post
    Ally and her whip a day helps keep the drama away!
    started building our coilovers and replacing all of our front bushings, also replaced the cat with a test pipe
    Cleaned the interior some more, gutted the steering wheel and removed a bunch of wiring and weight all around the car. SS brake lines up front added as well and new front sway bar endlinks with poly sway bushings. Rebuilt the shifter with new bushings and turret fluid
    11-18-2009
    Buffalo, NY
    1,758
    Those guages are awesome!
    - Chris -
    DRL Delete
    05-02-2008
    Hacienda Heights, CA
    3,014
    those are super dope bro!!!
    07-12-2007
    SoCal
    4,632
    Those gauges look plain in daylight but awesome at night!
    ok, so we polished up the car a little bit and drove it around a bunch just so our ears could bleed from the exhaust haha, I know we still need a new hood but we found one local for 110 bucks that's already red, and I'm driving up to seattle on thursday to pick up a roll bar for stupid cheap. Recaro pole position should be in relatively soon as well. I also replaced the softtop window with a home made concoction of rivets and clear vinyl.
    This is with my friend Nial's miata, which is clean as fuck and tastefully modded
