Thread: Got a Complete 99 eclipse 2.4 engine
Showing results 1 to 3 of 3
    Posey
    Hey all. So I pocked up a 99 2.4 eclipse engine for 100$ it's everything down to every last nut and bolt. I figure pretty good deal. He did say the car over heated and turn off. He said after he pulled the mot he got a new head gasket and tried a compression test. Said he got 0 compression dry and it went up a little bit with oil. Um going to have the heads clean and magma fluxed as well. I used curious if the head will work on my galant.
    Also what from this stuff can I use in my DOHC swap.
    06-16-2010
    Fort Mill, SC
    2,282
    Everything, except for the block and a few other parts. Vaw
    Sent from my iPod touch using Tapatalk
    -Andrew
    since you did ask that already in this thread
    https://www.thegalantcenter.org/showthread.php?t=47974
    and since there's nothing performance about this thread, guess what Im gonna answer this one more time. You can use the crank, pistons and rods, everything else will not work on 7g. Case closed
