Thread: 3.8L Avenger
Showing results 1 to 10 of 10
    3.8L Avenger
    Hey all,
    I'm almost done my 3.8L swap in my 1998 Avenger with a a543 5-speed manual transmission and I've got a question for you tech gurus.
    When KEY ON the C.O.P get extremely hot after a minute or 2.
    Will someone please turn their car to KEY ON, unplug one of the C.O.P connectors and tell me what the voltage reading is? I suspect that them receiving 12.4 volts is what is doing this and I need to confirm what the voltage needs to be. I remember somewhere that it might be 5 volts.
    Your help is greatly appreciated!
    Here's the car right now:
    2013 Viper GTS 600whp 157.89mph 1/2 mile best
    2005 Ram SRT10
    2005 Mustang GT
    2016 Maxima SR
    1998 and 99 Dodge Avengers
    12-02-2008
    Carteret & Manalapan, NJ
    1,263
    Dude keep up the good work!!!
    Your coil packs are over heating while the car is running? That happened to me it ended up being a broken ground so i made another one.
    Great job btw.
    Car isn't running yet. I just notice that they get really how with KEY ON position.
    Can anyone check this for me?
    2005 Ram SRT10
    2005 Mustang GT
    2016 Maxima SR
    12-13-2010
    Brooklyn, Maryland
    4,643
    Good work!! I'd be outside checking for you if I had a COP setup, sorry. Looks great though!
    -Greg
    Can anybody please just pull the plug and check the voltage real quick for me?
    2005 Ram SRT10
    2005 Mustang GT
    2016 Maxima SR
    We're not ignoring your request bro, Just the majority of the site are 8G's and 7G and we don't have COP. Though if the coil is getting hot it could either be bad or missing ground or an issue within the coil. Grab an ohmmeter and check the resistance on the coils they should be the same for all six you just need to find the spec on them.
    Jigz-TGCIL Sosick Motorsports
    11-29-2009
    Chadds Ford, PA
    2,768
    Also check out club4g they would be able to help more too
    Good call, i forgot about those guys.
    2005 Ram SRT10
    2005 Mustang GT
    2016 Maxima SR
    The A543 should bolt on to a 6g73 2.5 then?
